Front Heated Seat fuse?
GL 320 CDI
Both of my heated seats in the front stopped working at the same time. Makes me think this is electrical, so I wanted to check the fuses first.
I checked the fuse chart, but could not locate the fuse number for the front heated seats, only the rear. Anybody know which fuse I might check?
Fuses pretty much don't randomly blow.
The percentages are greater that there's really a problem and if a fuse indeed has blown it has simply done its job and protected the rest of the circuit.
Have dealer investigate and fix under warranty.
1 Post
2004 RX330, 2008 Scion xB, 2001 Honda Insight Hybrid, 2010 Toyot Prius v ATP
You sure you're not a pilot? That was always electrical rule #1 - if the breaker pops, think before you push it back in; it just did its job, why are you doubting its judgement?
