Leaking Air Suspension (Hydropneumatic Spring Leg)
I'm keeping the air suspension. I want the auto leveling as we tow and often take trips well loaded.
2013 Land Cruiser, 2007 GL450 [SOLD], 2007 Toyota Tundra Double Cab 4x4 Limited, 2009 Corolla LE
Dealer replaced on our 2007 GL450 - left front corner. I am glad we have extended warranty. Left front air strut was leaking. I would not mind going strutmasters when it goes out next time. I really don't use the ride height option anyways. Currently odometer is reading 80K miles. Couple more months of extended warranty. After that it is will be coming out of my pocket.
I just noticed this thread - the right rear on mine is leaking. I took it to the stealership so they could fix a couple things + replace the airbag. Apparently these things are on back-order.
Is this particularly common in the Gls?
They said they would call when they receive the airbag, and thankfully it'll be covered under ext. warranty, but I hope mine doesn't blow out in the meantime! It's been a couple weeks...oof...
2008 GL 320 CDI
I'm purchasing Arnott today and found a 10% promotional code...see copied link
Special discount from Arnott Air Suspension.
Use code GMForums0313 for 10% off Arnott GM Air Suspension Products.
* Offer good at the Arnott Web Store only on any Arnott Air Suspension Part. Offer valid on one purchase per customer with a maximum savings of $75. Savings not available on shipping, taxes or core charge. Hurry, Limited Time Offer.
https://www.facebook.com/#!/ArnottInc
#32
Hi guys,
My driver side (right, as I am in Australia) when BOOM last Saturday![Frown](https://mbworld.org/forums/images/smilies/frown.gif)
My mechanic want me to buy the whole suspension shock (not just the air bag) as he thinks he thinks he has no special tools just to change the air bag.
Since ALL Australian GL comes with the "Pro Off Road Kit", which shock should I be buying? The one with ADS, or without
(I have no idea what ADS mean
#34
Wonky air suspension
When I am driving the air ride will drop in the front, and some time later will re inflate. Sometimes when I park overnight the left front will deflate an d some times both fronts will and other times neither will until I touch the door handle and then I will hear air escape, not leak.
Any ideas![smash](https://mbworld.org/forums/images/smilies/smashfreak.gif)
Any ideas
#35
Have you replaced the air springs yet? They are "wear" parts, I've replaced 8 air springs between my two 2008 Mercedes. I did the R350 myself, and used my indy for our GL. I bought the parts from Arnott both times.
If you drive the vehicle too long with leaky air springs, you risk overworking and possibly ruining the air compressor.
This is a pretty straight forward issue, and is expected to happen between 75k and 100k miles.
#36
GL air bags suspencion
Any ideas
I did the work myself, was nothing special. Arnott has a youtube video as to how to change the air bags.
The total cost was about $1100.00 U$ dollars in parts, taxes and delivery.
https://www.arnottindustries.com/sea...el=69&year=146
#37
Inexpensive Airbag Replacement
I purchased my replacements here and my mechanic is $50 per hour to replace at 90 minutes or less per air bag.
https://www.arnottindustries.com/part_MERCEDES-BENZ_yid18_pid146.html
