brake pad life
After paying for lessons in the dealer's maintenance pricing schedules
($150 for an air filter/$165 for a fuel filter/$35 for a tire rotation that should have been done when the wheels were off for a brake inspection), I'm trying to decide if I will do these myself and how much longer I'll have to make decision...
but mostly the driver. Also ESP/ABR plays a large part in the pad life, your ESP/ABR system applies the pads to correct over and under steer and also controls tractions and tire spin it uses the brakes to regulate and also to reduces engine torque.
Ive seen the rears go on a gl550 at 15k and i knew the cust he drove like he was on a race track all the time
Its still taking me time to get used to the brake feel. They barely come on at light pedal ,and just a little more, the assist comes in hard. Much more difficult to modulate them compared to the recent cars we've had.
It throttles the engine to keep the same speed and does not use brakes.
It definitely uses the brakes with cruise.
Go down a steep hill at 40 MPH and set the cruise.
Then toggle the speed down and it will vigorously slow the vehicle (has to be using brakes)
Anyway, it does, unquestionably, use the brakes. I've had my foot follow the brake pedal down when it's doing it.
I am impressed with some of the mileage reports on the brakes. I am starting to wonder if my dealership was being totally honest with me when they told me I had "about 20 to 30 percent" left......
I even read an article on how cruise control works and it specifically mentioned that it does not use brakes.
I need to re-read that article again and do more research on this.
Thanks for highlighting this.
Make certain the article specifically applies to diesels (as well as gassers). Gassers have a throttle plate that can be used to create energy losses and decelerate the vehicle. Diesels do not. A moderate amount of drag is created when the tires spin the engine when no fuel is being injected (diesel). If more deceleration is needed by the cruise function, the system applies the brakes (probably rear first to help with stability). Gassers need less help braking but it is probable that Mercedes does not use different brake programming for the two variants
https://mbworld.org/forums/gl-class-...di-engine.html
