2010 GL450 Battery Issues-
Old Dec 7, 2010 | 10:18 PM
BlueRoy's Avatar
GL 350 Bluetec
Hood Release?
350 GL BT...cant open hood, there seems to be a lever in the middle right under the nose of the hood...but no matter how I push it up or down...the hood does not open. Help!
Old Dec 7, 2010 | 10:32 PM
43221B's Avatar
15 GL550
Push up on the release latch. Once it is fully pressed upward, lift up on the hood itself while maintaining pressure on the latch. The latch is just beneath the MB emblem.
Old Feb 11, 2012 | 09:34 PM
DeanP's Avatar
The no start/low battery issue requires a programming change. Had the problem, now it's gone 13000miles without that problem.
Old Mar 24, 2012 | 02:07 PM
Robyn Dawes's Avatar
MB GL350 Bluetec
What kind of programming change Dean P? I've just put the 3rd battery in my 2010 GL350 and am getting fed up. Problem seems to be getting rapidly worse. Please help!!
Old Dec 4, 2012 | 12:19 PM
RCorney17's Avatar
2007 GL450, 2003 BMW 325i
Originally Posted by Fourdiesel
Is this the pic you are looking for? The smaller battery at the lower right.
One must cut the carpet to get to these batteries correct? $49.95 from Pelican Parts as genuine MBZ battery online...
I've got the same "white" message occurring regularly now with "cooler" temps (for Cen Cal at least).
Old Sep 23, 2013 | 02:18 AM
atobacool's Avatar
gl 450
Angry EIS GL450 cost 4000$$
i need help, my benz agent gave me a bill of 4000$$$ for GL450 2011 EIS. is this the cost? where can i verify the cost please?
Old May 8, 2014 | 01:22 PM
  #32
Poppy diva's Avatar
Gl450
I own a 2010 GL 450.for sometime,it's been reading auxilliary battery malfunction which disappears after few minutes of drive
It got worse when suddenly the ignition refuses to shut down and does not respond to any command.after almost an hour,the engine shut down but wasn't responding to any command.
After a bit, it reprogrammed itself and was working perfectly only to have the same thing repeat itself again.
What can I do?
Old May 26, 2014 | 08:28 PM
  #33
drgeeforce's Avatar
2010 GL350, 2005 BMW X5 4.8is, 2015 BMW 328d
for what its worth, I found out the KeylessGo has two settings: 1st press is accessory power, radio, windows, REST,etc. similar to key position 1. 2nd press diagnostic+ ON similar to key position 2. If you hit the button without stepping on the brake, the car electrical is on and engine is off, slowly draining the battery. Also I would check the rear DVD player, if equipped, to see if there is a video playing, that would drain a battery. Courtesy reading lights left on will also drain a battery. If battery life is an issue, check the alternator, the voltage regulator will often be a culprit of undercharging the battery. Remember AGM batteries are not Deep Cycle and not meant for long accessory use. Don't leave the headlights on for too long without the engine on. Frequent short trips will not provide enough charging time. REST will drain a battery.
