Coolant
Old Apr 4, 2010 | 10:27 PM
jw1977's Avatar
GL450
Coolant
My coolant light is on in our 07 GL450. Is this the pink or green coolant?
Old Apr 5, 2010 | 02:35 PM
jw1977's Avatar
GL450
Anyone? I looked at the resevoir and can't see any fluid. Also, I see no high or low mark on the resevoir. Am I missing it?
Old Apr 5, 2010 | 02:39 PM
MomsBenz's Avatar
2011 GL450
My '09 has the pink/red coolant. I didn't see the high-low mark either. There is a ridge that I filled mine too as my coolant light came on as well. In the back of your owners manual there is the coolant spec's.
Old May 4, 2010 | 03:30 AM
Petmerctech's Avatar
Pink/ red coolant??? It's neither pink/ red or green. You need to use MB spec coolant from the dealer or aftermarket equivalent.
Old May 4, 2010 | 09:56 PM
Popo's Avatar
2007 GL450 2005 C55 2002 C32 sold 2001 ML320 sold
You should be using Zerex G05 only for later model MBs. It protects the aluminium parts of the cooling system. I use a 50/50 mix with distilled water as i live in Chicago and change it every 3 years in all my cars.
