7 pin to 5 pin problem -anybody have a fix?
Thanks,
Roy
When I got my trailer hitch (MB hitch attached afterwards, way too expensive to do it that way compared to ordering it for those curious), they included the 7-4 conversion only, so I don't know if MB even makes one that's guaranteed "right." Of course, it's worth it to know if the plug is correctly wired to begin with. Having either a trailer with a 7 plug or a volt meter, a friend and some patience can help in that area!
The product images online only show it being 5pin, which doesn't allow plugging in a 4pin cable connector.
How does it convert from 5pin to 4pin?
Does it come with two little rectangular insertable modules so you can pick either?
Thanks.
Surge brakes are used on smaller boat trailers but you will often find electric systems on larger boat trailers. These systems are actually electric over hydraulic which use an actuator motor mounted up high which generates hydraulic pressure to the brake pistons. That way no electronic components get wet when launching the boat.
Therefore BlueRoy, if you have an electric brakers on your boat trailer you need to have a trailer brake controller installed to actuate them.
the one still at my house that didn’t work with stepdaughter’s horse trailer is marked “center pin e. Brake.”
the one she’s using is marked marked something else. Probably from etrailer.com
