GL350 Mileage
Old Jun 20, 2010 | 11:04 PM
newyorktoLA's Avatar
2020 G63, 2021 E450 All-Terrain Wagon
GL350 Mileage
Today, I averaged 15.7 mpg with my GL350 during mixed city/highway driving on a 70 mile trip. Is this normal? Whenever I fill up now, my range is only 400 and something miles, not 600 like it was before. If there is anything wrong, what should I do to fix it???
Thanks in advanced.
Old Jun 20, 2010 | 11:08 PM
dbtk's Avatar
600 SWB
Get 23.5 on mixed driving.
Old Jun 21, 2010 | 07:14 AM
43221B's Avatar
15 GL550
That seems low under any circumstance other than towing. Take it to the dealership and have them diagnose it.
Old Jun 21, 2010 | 10:48 AM
alx's Avatar
alx
yes. this is very low.
you should be averaging about 20 in mixed normal driving.
25-27 is the norm for highway and 17-20 for strictly city traffic
at least that is my experience
Old Jun 21, 2010 | 10:54 AM
Brocktoon's Avatar
GL 320cdi, Chevrolet Avalanchero, GLE 350 (on order)
Lots of stop & go, idling and heavy A/C use can pull your average down substantially. Don't forget it is a distance/consumption equation, so every moment stopped adds consumption without distance. So, even over 70 miles, it might be hard to make up for 10 minutes of idling or stuck in traffic, by the computers reckoning.
Any of this apply?
Old Jun 21, 2010 | 07:39 PM
jimmyp's Avatar
I get around 19.5-20.5 city and 25.5 highway with 1200miles on my new truck.
Old Jun 21, 2010 | 10:02 PM
ksalno's Avatar
2011 Audi A4, 2014 E63S Wagon, 2020 GLS 580
I was just scrolling through my mileage calculations and am averaging just under 20 mpg over the 2800 miles of mixed miles I have on my GL350.
Old Jun 22, 2010 | 02:38 AM
fs1013's Avatar
2010 E350 Coupe, 2010 GL350 Bluetec
I am traveling and can't verify to the car. But that sounds right from memory.
Mine is now just over 5000 miles and mostly city. I gave it a test for highway a couple weeks ago on a trip of 65 miles. Reset it when I got on highway and read as soon as I got off. I set the cruise at 65 mph (with Distronic). The reading was just over 30mpg and that included 15 minutes bumper to bumper through the city.
Old Jun 22, 2010 | 11:58 AM
lkchris's Avatar
'10 CL550, '12 GL550
Did EPA figures change between 2009 and 2010?
Between GL320 and GL350 that is?
If it makes more power it takes more fuel to do it.
Old Jun 22, 2010 | 12:33 PM
43221B's Avatar
15 GL550
Funny you should bring this up. There has been a lot made of the few (2 I think) pound feet of torque increase of the 10 over the 09 but I have never heard of an engineering explanation of where they are getting the extra torque. Interestingly, in my 09 manual, it lists the torque specs for the 320 at 400 lb ft, same as the 350. On the window sticker, it was listed as 398 lb ft. Makes me wonder if there was a typo in the 09 manual or if there really was a change between the years. I have heard that some manufacturers don't always include all the power in their specs particularly when an engine is used across multiple models.
BTW no, the EPA numbers didn't change. I'm not sure if 2 lb/ft of torque would change the numbers though. 2 lb/ft is what, a .5% increase?
Old Jun 22, 2010 | 06:34 PM
Fourdiesel's Avatar
2008 GL 320 CDI, 2004 VW V10 Touareg TDI
Just because an engine CAN make more power [torque] doesn't mean it does in actual use. The fuel to create 100 lb-ft of torque is the same regardless of engine (as long as the engines are the same basic design - pistons, bore, etc and the same order of magnitude in general torque / horsepower peak output). Small differences in rated peak output will have no effect on the fuel consumption at fractional output. There are undoubtedly differences in the 320 vs the 350 efficiency due to different fuel maps because less egr recirculation is necessary on the 350 due to the availability of BluTec fluid to control NOx.
Old Jun 22, 2010 | 09:30 PM
43221B's Avatar
15 GL550
Originally Posted by Fourdiesel
... There are undoubtedly differences in the 320 vs the 350 efficiency due to different fuel maps because less egr recirculation is necessary on the 350 due to the availability of BluTec fluid to control NOx.
I agree with you but do you have any insight on the difference between the 2009 320 Bluetec and the 2010 350 Bluetec? I'm sort of sceptical of there being any real difference.
Old Jun 23, 2010 | 08:14 PM
Fourdiesel's Avatar
I don't have any direct knowledge of the differences. Even the emission requirements differences are minimal. If I had to guess I'd say the difference is 30. 350-320=30!
Old Jul 2, 2010 | 05:59 PM
rich4368's Avatar
2010 GL350
I had that problem with my 2010 GL350. My GL350 was getting about 16 mpg in 30-40 mph driving with range of 5-10 miles and 19-20 mpg on highways. I brought my truck in three times for dianostics but nothing found until CEL came on on my third trip to dealer and they finally diagnosed the faulty adblue pump and had that replaced. That was 2 months ago with 7,000 miles. Now I am closer to 10,000 miles and mpg has been great. Did a round trip from Bay Area to San Luis Obispo averaging 25-26 mpg the whole trip with AC running half the time. In city driving I am getting 22-23 mpg. Check out the previous link: https://mbworld.org/forums/gl-class-...ine-light.html
Old Jul 12, 2010 | 11:20 PM
DucatiNut's Avatar
CLS55 plus a few Ducati's
Always get around 21 around town. If I drive it very carefully I have seen 35 on a 350 mile trip! Your mileage is WAY low.
Old Jul 13, 2010 | 12:48 PM
StevethePilot's Avatar
2004 RX330, 2008 Scion xB, 2001 Honda Insight Hybrid, 2010 Toyot Prius v ATP
35mpg over an entire 350 mile trip? That has to have been in absolutely ideal conditions. Loaded with four people, two small dogs and all our clothes/etc. for a long weekend, and with crosswinds the whole time, I got around 22mpg average at freeway speeds (I-10 in to about Los Angeles, fairly flat). If you're doing actual calculations (and not relying on the trip computer) that show 35mpg average over an entire 350 mile trip and not just one section or something, I'm very impressed. And a little confused.
Old Jul 13, 2010 | 10:03 PM
dbtk's Avatar
600 SWB
Just got back from a 2,900 mile trip back and forth to Disney World from Connecticut. 27.9 mpg averaging 70-75 mph on the freeway, A/C on, and several rain storms on the way back up.
Old Jul 14, 2010 | 12:33 PM
43221B's Avatar
15 GL550
The diesel is pretty incredible on those long trips. How many miles were you going between fillups?
Old Jul 14, 2010 | 01:05 PM
dbtk's Avatar
600 SWB
As few as 300 miles and as many as 500 miles. I was trying to optimize tank fill-ups and the price of fuel. In some cases through VA and NC, I found diesel for as low as $2.699 per gallon (a far cry from $3.519 in CT).
Old Jul 21, 2010 | 09:56 PM
HamMan's Avatar
2015 E400 Cab - 2013 GL350 - 2013 ML350 - 2006 E350 - Old Jeep
My best mpg in a 2009 320
Attached Thumbnails GL350 Mileage-real-world-29.3-mpg.jpg   GL350 Mileage-4-8-10-28-mpg.jpg
Old Jul 22, 2010 | 12:20 PM
I'm not impressed with the onboard computer. This is my best mileage, based on my 2007 320's computer! I'm afraid manual calculations are the only reliable way to know real mileage, or at least a more reliable way.
Old Aug 2, 2010 | 05:46 PM
43221B's Avatar
15 GL550
The diesel runs one gear lower that it needs to at speeds between about 25 and 45 mph. Only when gently accelerating for quite some time will it "learn" to run in a higher gear at those speeds. So, if you want even better mileage, use your right paddle to shift up a gear at speeds below 45. This has been discussed before but I think it is worth repeating for new 350 owners.
Old Aug 4, 2010 | 08:33 PM
Fourdiesel's Avatar
I hope the '09-'10s have a better response to the shift paddles than my '08 does. I have tried and tried to get my '08 to upshift at 25-40 mph - 1400-2100 rpm, going slightly downhill, small added throttle (or none) and I have concluded my tranny is dyslexic! NO upshift - ever - until a full 30 seconds has past or I get to 50 mph. To me, the paddles are almost useless. Click once on the left paddle (even by mistake when turning a corner) and you get the LOWSET gear possible rather than the next gear down. On upshift with the right paddle you sometimes get one gear at a time but other times it jumps all the way to drive. I never can tell when this is going to happen.
I would also like to see the actual gear it is in displayed (where P/N/D show) rather than just the D all the time.
Old Aug 4, 2010 | 08:39 PM
WEIRD! On my wheel, the paddles are rockers and the outside of the buttons is up-shift, the inside is down shift. That helps avoid the "mistake" button press. I wonder if that's a Startek thing or something unique to the wood/leather wheel I replaced my OEM with?
Old Aug 4, 2010 | 08:43 PM
Fourdiesel's Avatar
On mine (stock m-b text wheel w/ heat) the switches are rockers but are only momentary contact single throw - ie 'on' or 'off'. Left side for downshift, right side for upshift (but only when all other parameters are satisfied, including pissing me off!)
