Anyone towing a big load? Did you reinforce the factory hitch?
Regarding the Andersen, yes, it does increase strain on hitch parts, because it's urethane bushing has much less range of motion than a conventional spring bar WDH. So going through big dips like approaching some gas stations puts an enormous front-to-rear twisting load on the hitch and its mounting points.
The Andersen's are reported by many in Travel Trailer forums not so transfer as much weight as conventional WD hitches, but they are very good at controlling sway.
I think any factory-installed hitch since since 2010 has the increased reinforcement, and wouldn't expect stress cracking.
By the way, our EaZ-Lift, with trunnion spring bars and friction sway bars is a superior system.
Ha. I came up with a more favorable ratio for the ML, but my point was that many people think that the only good tow vehicle (TV) is a LWB 4 Door pickup - thinking that wheelbase is the important factor.
Others think that the wheelbase of the tow vehicle vs the length of the trailer determines stability.
But physics shows that the rear overhang to wheelbase is the important ratio. TV WB to trailer length is not a part of the equation - the TV only sees the trailer as a mass. It's not a myth, it's a noticeable fact. You CAN feel the difference even a shorter shank makes.
In any case, I don't think 1/2 Ton pickups are as capable tow vehicles as a good stout SUV. Plus you can't park the darn things - too long. For me, the GL is to long to tow with, too. For my use the ML is superior. YMMV.
And don't get me wrong, I believe ML/GL are great tow vehicles: powerful, stable, comfortable and efficient. They have a max rating though (7200# for ML, and 7500# for GL). If you plan to tow 8500#, you cannot use them -- or any other unibody vehicle for that matter (unibody gives ML/GL good ride and handling characteristics). That why trucks exist. They may not be as refined, but they can tow more. So, there is no point doing the truck vs unibody battle. They serve different audiences (lighter vs heavier trailer owners).
1. Total trailer weight: 7000 - 7500 Lbs depending on If I'm bringing motorcycles with me to the racetrack
2. Tongue weight :800Lbs Initially, measured with a sherline tongue scale. I moved cargo back and reduced this to 700lbs.
3. Factory recall completed? yes
4. Additional welding completed? Yes, see my pictures above, message #44. so far the re-enforced hitch is holding up well.
5. using a weight distribution hitch? yes, Equalizer, 10,000 / 1,000 model
My GL320 CDI is a great tow vehicle so far, after dealing with the OEM hitch.
A comment to HBillsmith's comment on Suspension. I'm sorry to hear that. I've had multiple problems with my airmatic suspension as well, bag leaks, on all 4 bags over time. First 2 were bad enough that it burned out the pump. However all my issues were before I towed anything.
I too am ready to reinforce the hitch, so that I can tow a 7000 pound trailer, but that still does not change the fact that the max payload posted right on the door, is 1180 pounds. That number also includes the tongue weight . So, if I'm towing a trailer with 850 pound tongue weight, it means I only have 330 pounds left for everything else in the car.
If I put down 180 pounds for myself, then it means that I only have room for my wife, and 1/2 of one of my kids, and no luggage ....
Are all you folks towing, actually done the correct calculations ? It seems to me, they are cutting the tongue weight down to make sure you have more capacity in the car vs a weak hitch ...
Please see my post in this thread from a few years ago on calculating carrying capacity and cargo vs. hitch weight for the GL... It should answer your question pretty thoroughly... If you still want more, happy to help.
https://mbworld.org/forums/gl-class-...assengers.html
So, that makes a lot more sense . Thanks for the clarification .
Do you have your hitch reinforced ?
I'm looking at the grand Design 2800BH . the dry tongue weight is about 575 pounds .... it has a huge basement in the front, but I can live without it, I'm also going to route the battery back to the bumper, and just use 18650 battery pack (that is my hobby - reuse old laptop batteries) ..
So. it leaves me with 575 + 40 pounds for propane ...... I have also seen the hitch scales on amazon that would make it easier to weight the hitch .....
However I'm hesitant to want to pack it, to keep the hitch at 600 pounds, just because of my experience of towing a very large boat behind my expedition - it was not fun ....
What would you recommend ?
I did have my hitch receiver reinforced out of an abundance of caution. Back when I did this, about six years ago, there were horror stories of early model diesel GL's having their hitch receiver torn off by heavy loads. I have not heard any more of these stories since Mercedes did the recall on early model GL's to reinforce their hitch receivers. For my GL, I had a trailer shop weld in triangular 3/8" plate steel gussets between the hitch receiver and the bumper tube.
My best practice is to load my airstream over its axles whenever possible. I also try to travel with empty water and waste tanks when I am not going boondocking. And I don't carry heavy loads in the back of the GL when I am towing. What I try to avoid is either loading the front of the airstream, which would increase the tongue weight, or loading the far rear of the airstream, which would decrease tongue weight and reduce stability.
What I can report is that my 2011 GL 350 drives well and tows well and I have not had any towing related issues or white knuckle moments in about 20,000 miles of towing the airstream. On the other hand, at just 70,000 miles, my GL has also been hideously, embarrassingly unreliable over all.
Did not reinforce the hitch as I did not see much under there that looked any stronger than the hitch and early on I was worried about warranty issues. My trailer has a 8400 gvwr, but I never tow over 7200lbs and nothing but me, wife and kids in GL. Relocated batteries and few other items to the rear of the trailer and have weighed it on the CAT scales (truck stop). Using the ProPride hitch I have the weight equalized to 55% rear and 45% to front.
As far as reliability I seem to have passed some milestones and things have been much better the last year or so. Almost all of the emission system has been replaced, all Airmatic parts but the manibloc have been replaced, timing chain, oil cooler seal. Motor mounts are the only thing that needs to be done but really like the vehicle despite its "character" issues....
As far reliability, I'm there with you ... It seems anything that can go wrong with the Diesels has gone wrong with mine up to 80k miles ...
But surprisingly, and I know I just jinxed it, I have not had any issues in the last 10k miles (currently at 90k) - from 40k to 80k miles I could never go more than 3k miles without something going wrong .
Edit: You will also want to get an OEM harness and find someone with STAR to program your car for trailer detection. Yes, the trailer bulb out warning can be annoying, but there are far more advantages such as trailer sway control and delayed shifting.
Don't go aftermarket, because they lack the internal reinforcements mentioned by @Tsumi .
You are the one making gross baseless assumptions, not us.
Curt markets and sells Class III hitches for W164 and X164 that are rated to 3500-4000 lbs maximum. That is a fact. The only way to get max tow capacity is with the OEM hitch. That is also a fact.
Edit: also more facts:
Class I- 1-1/4" receiver, up to 2k lbs
Class II- 1-1/4" receiver, up to 3.5k lbs
Class III- 2" receiver, up to 8k lbs
Therefore, a 2" receiver hitch is at minimum Class III even if it is only rated for 3.5k lbs. That's because Class II hitches come with 1-1/4" receivers.
2nd edit: Also, class ratings are very loosely followed. These ratings are according to Curt, yet they also make a Class I hitch for a 2004 Corvette that is rated to 2.5k lbs. I believe Mercedes calls their OEM ML and GL hitches Class IV hitches even though none of them are rated above Class III.
However, using terms like "gross, baseless assumptions" has nothing to do with me taking things personally (which I am not). It just shows how quickly some people can fly off the handle. Maybe that's not a true represention of who you are - I don't have that answer - but remarks like that make it appear that way.
Also, taking the time to push Curt hitches while not taking the 5 minutes it takes to realize that Curt does not have anything which fits the bill is doing the community a disservice. It makes you come across as a Curt shill.
Mini was repaired under warranty
