Thread resurrection: I followed the advice posted here, and pretty easily swapped out the cabin filters through the engine compartment. I previously went through the glove box, and while that isn't hard, it's still a hassle. Engine compartment change just requires you to commit a bit, and really grab the right filter and pull it out. There is a lip that run the perimeter of the compartment that holds them in place. Just grab the old filter and pinch the front in a bit to clear the lip. Then it's easy. Installation went smoothly, just had to forcefully push it down into the spot. Worst case scenario, you can't get to slide in, just go through the glove box and slide them in that way.
Did the engine air filters at the same time.
Reason: Adding photo
