The Tire Tread?
That's, umm, rarer here.
Let's face it, most of what people get with upgraded tires in the US is more high speed lateral grip. That's awesome 2 days per year on your 911 Turbo, but a lot less interesting on, well, everything else.
- Mark, has some experience in this area
They are both Sedans, and maybe just used to go down to Safeway. Their use and form is irrelevant, it is what the car is set up to use. The GL is designed with the supposition that a high quality touring tire or performance tire be used. How can I tell? Again, just look at the rear camber, that's your first hint.
BTW, my current Escalade has more torque than any of the GLs and is basically a "solid axle Tahoe."
We agree on the carcass design.
- Mark
You are totally correct about your car's suspension. You have what, 415 lb/ft? GL 420 has 515 lb/ft, the lowly US 320s and 350s have 398-400 depending on the year so it is similar, anyhow, but that is beside the point.
A solid axle works fine in the Escalade, and you could likely get away with more of an LT style tire because of it, because it is, after all a light truck platform. Because of this, the suspension hard points are for the most part carried over from a Silverado, and by their hauling nature, they don't introduce excessive camber into the suspension.
The independent suspension on the GL is a different story. There is a reason the GL has posted the fastest slalom times on any full sized truck in several publications, and that only comes from the suspension. Because, after all, you are dealing with four wheels in similar places, carrying around similar weight.
Keeping things simple, lets just stick to the rear suspension. The GL, like your wife's 5 has a considerable amount of camber dialed in. What this means is that the truck is basically riding around with all the rear axle weight on the inside edge of the tire. When you turn, the inside tire then become more perpendicular to the road, and of course you can figure out what that means. The exact opposite wants to happen on a solid axle. By nature, tires optimized for one, won't be ideal on the other.
Knowing all of this, I would without a doubt expect tires on an Escalade to last longer than a GL. The GL's suspension has the most even contact patch on the loaded wheels when turning, the Escalade, when going straight. I don't know about you, but I spend more time going straight.
As far as I'm concerned, you go into this type car knowing that tire wear will be worse than other cars. As you can see, it is the nature of the beast, as they say.
So let's just agree to disagree unless we ever meet in person, at which point we can argue about it for hours over a beer or three.
- Mark
I think you have the 450 confused with the 420, and the 550 confused with the 350. I don't even think they sell the 420 down there so you may want to check out Mercedes UK or something.
But my apologies, I read your GL 420 as a typo on GL 450 (and replicated it myself!), since we don't get the 420 diesel in the US and I had forgotten that you're in Canada.
- Mark
- Mark
