Tow hitch favor
Tow hitch favor
Can someone with the tow package (preferably with 20" rims) do me a favor?
Can you please measure the distance from the ground (at normal ride height) to the lower inside edge of the tow hitch receiver? Basically, I want to know how far off the ground the receiver is in advance of my '11 GL350 showing up so I can get my hitch platform reset since the current Escalade receiver is definitely farther off the ground.
Thanks!
BTW, if you tow heavy, you should consider a ProPride 3P Hitch. I cannot recommend it highly enough:
http://www.propridehitch.com/product...ol-Hitch-.html
- Mark, GL350 custom order (ADS II) inbound
Thanks!
I have an 11 GL 350 bluetec with factory 20" rims/ runflats. Took delivery late November. I measured 13 5/8". Hope this helps.
Your welcome Mark. By the way, I pull a 22' center console boat on an aluminum trailer with tandem axle with surge disc breaks on all 4 wheels. Total load just over 5K lbs. Absolutely no problems. The listed capacity of the GL towing is what 7K? What do you tow to use such an expensive non sway system? I Have pulled the same boat with an 07' ML 320 CDI and 08' GL 320 CDI. Have you pulled anything with a GL yet. If you already have the system, that is one thing, but I would find it hard to spend that amount of money with the way the GL tows. Wind resistance? My center console has a fiberglass "T" top that is non removable. Great bug catcher and sail. I'm sure not as much as a camper trailer or a closed car trailer due to the box shape but my experience has been great. I pull the boat from Louisville to Destin Florida without blinking. I'm interested in hearing what you are pulling. When is your ride arriving. Also are you getting the bluetec? If so, the torque will blow away your Excalade's torque.
It's got the aerodynamics of a barn door. Hell, of the whole barn.
I get 7.5 mpg towing it with the Escalade on level straight highway with the cruise locked at 62 mph. Can't wait to see what the GL gets under the same circumstances.
Yep, Bluetec. It's actually a bit lower torque-wise than my Escalade (417 lb-ft), but it comes in WAY lower in the rpm range and should be a towing monster more on par with my old 2002 GMC Crew Cab with Duramax diesel. Just without, you know, the tupperware interior that the GMC had.
I missed having a diesel around.
Anyway, I'll definitely post a review after my first tow in the GL. That ProPride hitch really is amazing, so I suspect that towing will be an all-around painless experience in this rig.
- Mark
I actually use a 6" rise for my boat. Works out great. I use the system that another poster listed that actually bolts in place so you don't have to listen to the clunking all the time as the load shifts. I'll find the link and post it later.
It's a 22' enclosed V-nose race trailer with a race car ('94 BMW 35is) inside. Total weight is right at the GL limit.
It's got the aerodynamics of a barn door. Hell, of the whole barn.![Smilie](https://mbworld.org/forums/images/smilies/smile.gif)
Yep, Bluetec. It's actually a bit lower torque-wise than my Escalade (417 lb-ft), but it comes in WAY lower in the rpm range and should be a towing monster more on par with my old 2002 GMC Crew Cab with Duramax diesel. Just without, you know, the tupperware interior that the GMC had. ![Smilie](https://mbworld.org/forums/images/smilies/smile.gif)
On another note, the factory hitch setup appears slightly different on my 11 GL than previous versions. With the bad weather, I have not gotten under the rear to see if it is different or not. Another poster discussed modifying the setup for additional strength. I don't know if you have read that or not. With you maxing out the towing capacity, you may want to check out his mods to see if you may want to consider that as well.
Cheers!
![drive](https://mbworld.org/forums/images/smilies/driving.gif)
I'm leaning toward having my race shop reinforce the stock receiver at a minimum. Welding some gussets on would be easy. I'd like to avoid the additional bar under the AdBlue tank that some people have added - it seems like it has unfortunate ramifications for the vehicle's crash performance.
- Mark
- Mark
- Mark
Note also that vehicle is going to lower itself at speed, but this is likely insignificant with respect to towing ... so it's a little difficult to measure "normal ride height" with vehicle stopped.
Mercedes ESC (electronic stability control) already built into the GL provides trailer antisway. I believe on USA models the factory wiring still provides burglar alarm protection should trailer be disconnected with alarm activated.
For my Westfalia/BMW motorcycle trailer I think my formula is 1-in drop upside down.
The ESC brakes individual wheels (fronts, in this case) to manage sway. When it has to do that constantly, you end up with overheated brakes. Which means you ain't gonna have 'em when you really need 'em.
- Mark
I just put my hitch on myself. The hitch is much better then the old units. The drop support goes all the way around the hitch bar now, not just welded to it like befor. I towed my supra its about 5500lbs with trailer and I got 16.5 mpg with my 2010 gl350.
Great news - thank you.
- Mark
2014 slk55 amg, 2011 gl350, lambo gallardo, 800hp supercharged viper
![EEK!](https://mbworld.org/forums/images/smilies/eek.gif)
MB
If anyone has the newer hitch can they please post tongue weight specs?
I'd be curious to see if overall capacity has increased. If so, I'm trading in our GL550...
1 Post
2004 RX330, 2008 Scion xB, 2001 Honda Insight Hybrid, 2010 Toyot Prius v ATP
Of course, even though my towing is for miniscule weights, suddenly I become OCD and feel I need to go out and check the tightness of the hitch and the ball about every 231 feet. But beyond that it's a nice unit.
I've found you need to screw in the bolt, push the lock on until it clicks, then torque it the rest of the way down, hook up (though I've barely towed any weight, honestly) and re-check the tightness of the bolt.
I have pulled the boat about 600 miles without any issue so far on both interstate and windy back roads to different lakes. No sway problems and the bolt never budged.
