Rough riding GL350
- Mark
).There's probably some equivalent for air springs. Worth checking.
- Mark
When you say the ride is "rough", do you mean it's harsher or more active? You feel more of the road or you're being thrown around inside the cabin more? (Were all of your other cars Cadillac Fleetwoods?
)The general consensus on this board is the ride to those who've complained the most is too soft, wallowy, and boaty. Those who've moved from the original to run-flat tires are fairly evenly split on whether the ride is better or worse (and road noise, etc.)
What could be wrong is (like was already said) something used in shipping not removed. You could also have some kind of malfunction in your air ride system, missing or broken parts, all kinds of possibilities. It'll take a mechanic peering around under there to tell you if something's wrong. But if the ride's the same with any same-model-year 450 or 350, then nothing is wrong with the car mechanically, it's just not to your liking.
When I try to enter the local Home Depot underground parking garage, I know to have all my passengers brace themselves, as I know this particular spot can cause the effect to the degree that people have hit their heads on the door glass or b-pillar in the past.
That being said, I would not consider that a "rough ride", just an unforunate dynamic characteristic. I can see how if you had to drive over ramps and curbs like that all day, it would be too much!
What basically happens is that you have a tall vehicle, so it sways a lot. The engineers compromise with stiff sway bars, with are really just a torsion spring that connect the two sides of a vehicle together. When you hit a single-wheel bump (like entering a driveway diagonally), it twists the sway bar. When the suspension unloads, the sway bar twists back. Since the vehicle is tall, it acts like a lever arm and you get tossed sideways a lot.
- Mark
- Mark
I live in a town that spends zero money on their roads, so we have potholes galore...I did find the ride a bit more "harsh" than I had anticipated at first, but even in my problematic GL, I have very little complaints about the smoothness of the ride, especially on the open road. Run flats wouldn't be my #1 choice, but they did win me over on the freeways. But I also agree with Brocktoon on the perpendicular thing...I have noticed that it goes a little 'back and forth' more if you don't hit things head on. There is a speed bump right on the 90 degree corner going into my banks ATM and it sends my car a little "wonky" everytime I drive over it. I wouldn't say it tosses us 'violently' back and forth but it's a good "jostle."
The way a lowering mod would soften things up would be through the air pressure in the bags. The lower the pressure in the air springs the lower the ride height. Lower spring pressure equals softer ride and so goes the opposite. Jacked up height equals stone like suspension feel. Although its cool for cruising around town and being able to see over the snow banks
So, does the Q have a closed cross linked system? or is it open like airmatic? I think an open cross linked system is possible with the right valving. That must give a very nice ride indeed.
http://www.justcar.org/2011-infiniti...walkaround.php
The Qx56 suspension looks boss! No sway bars, cross-linked hydro-pneumatic, with an open air system for load leveling at the rear! That must ride like a dream!
1. its a Nissan
2. not diesel
3. thought the ride sort of wallowed, but I guess that it may have been better than the GL just to the opposite end of the scale.
4. the wife didnt like it
5. its a Nissan
6. first year for the model, although its built on the Patrol platform which has been around awhile
7. its a Nissan. Nissan engineers are all the Toyota and Honda flunkies
1. its a Nissan
2. not diesel
5. its a Nissan
