White GL owners - how's your paint holding up?
Old Apr 18, 2011 | 09:37 AM
ddcha's Avatar
2022 E53 SG
I was giving the car a wash and wax yesterday when I noticed, particularly on the rear hatch of the car, there are these rough black little specks all over the paint. I was able to get some of it out with a compound, but still pretty bad. Pictures wouldn't pick it up. Anyone else with this issue? Should I make a warranty claim?
Old Apr 18, 2011 | 09:42 AM
ima55r2's Avatar
2018 Mclaren 720s, 2021 Aston Martin DBX
Try a clay bar before doing anything else.
Old Apr 18, 2011 | 10:32 AM
43221B's Avatar
15 GL550
+1 on the clay bar. Go to meguiars.com and you should be able to find a video of proper usage. Meguiars bug and tar remover might also do the trick. It even removes the little rust stains on the running boards that show up from the salt brine.
Old Apr 18, 2011 | 10:47 AM
ddcha's Avatar
2022 E53 SG
will try that thanks.
Old Apr 19, 2011 | 01:53 AM
Max Blast's Avatar
NGL450 w/EORP, S550
yep clay bar. My white paint is holding up just fine in desert heat.
Old Apr 19, 2011 | 12:56 PM
dougpark714's Avatar
diamond white is holding up nicely so far.
Old Apr 19, 2011 | 09:46 PM
1st amg's Avatar
SLS Irridium silver,2014 GL350 BT Irridium, 2015 White Dodge RAM Hemi Quad
The clay bar will remove that road grime and road tar, I am sure you probably also noticed little rusty speckles as well, this is common as the particles from the brake compounds attach themselves to the white paint and they turn into little rust spots, this also is removed with the clay bar, but you will have to use some elbow grease. I have owned numerous white trucks and this is always the pain of owning a white car, but when you are done with the clay bar and you have added a wax the car looks awesome.
