My GL stuck in wet grass...
Tires more than anything, although lockers will help. No problems with snow tires for me on literal ice rinks getting traction, but wet leaves/grass is a killer for almost all systems, including traditional transfer case systems with rear posi.
There are lots of vids on youtube of all kinds of 4x4s stuck in seemingly mild situations.
Time for a UniMog?
'09 SL Black, '12 ML63, '13 SL63, '14 E63 Wagon, '14 458 Italia
I have to chalk this one up to tires. As far as the GL's capability when properly equipped, in the record snowstorm in the DC / MD / VA area a couple years ago, I not only passed 3 stuck snowplows, I roamed DC for two days without getting stuck once. So slap the right tires on and have fun wherever you want.
![](http://i996.photobucket.com/albums/af85/thomas_kobayashi/IMG_1049-1.jpg)
2014 slk55 amg, 2011 gl350, lambo gallardo, 800hp supercharged viper
I have the standard tires on my GL350 which are 20 inch 275/50/r20 Goodyear Eagle LS, the tires it comes with from the factory.
I didnt have a problem in the snow this winter with the GL. My thinking is because there was always hard road beneath the snow. When there was no hard surface to support the 6000lb weight of the GL in the wet grass there was nothing for it to grip onto. As said before I tried pretty much everything. I dont have the offroad package but I tried it with ESP on and Off. I turned on the offroad button, tried it on and off. Raised the height of the vehicle, and downshifted with paddle shifters. I even put pieces of wood under all 4 tires and still couldnt get traction. ALL 4 tires were spinning.
If all 4 tires were spinning then your tires were the sole problem that day. ESP, diff locks, downshifting, lowrange, etc.... won't help. All those systems are designed to direct power to the wheel with traction. In your case the tire treads were fully packed with mud and acting like slicks and providing zero traction.
#32
#33
2015 Ram 2500, former 2013 GL350, 2007 GL450
My experience is wet grass can be one of the toughest things to get traction on. It starts to slip and as soon as it does the grass is gone and the tread fills up with mud. I've experienced wet grass slippage in hay fields, etc with my Dodge Ram 2500 before with good tires. Fortunately it happens when I'm in 2WD and moving to 4WD and going easy I've never gotten stuck. I've been in feet of snow, muddy roads, steep conditions and nothing is as easy to slip on as wet grass.
But I could see in the right conditions of wet grass, 4WD, quickly filling the tread with mud that it would be hard to move out of even a small dip in the turf created by the spin.
I don't see this as driver error. I think that tires that are better suited would have prevented getting stuck, but you probably still could have spun the wheels on the wet grass. I suppose it could be argued that you could have reacted faster and not spun so deep, but I certainly wouldn't criticize you for that. It's not a situation where you'd expect to spin the wheels.
#34
2013 650i Coupe, 2010 IS250 AWD, 1999 S500
M
#35
08 GL450
Next time you anticipate driving on soft ground/ wet grass , carry a bag of kitty litter - that stuff thrown under slipping tires works very well !
I've helped many a friend with front wheel drive slippage on the upward hill of our winter place get unstuck by tossing some of it under their spinning wheels when icy .
#37
I had a 3/4 ton 4wd pickup equipped with BFG all terains get stuck on wet grass / slick mud once. I was parked on a very slight incline at a produce stand on the edge of an apple orchard.
I imagine I could have gunned the engine hard enough to dig some ruts and rock myself out, but I did not want to cause damage. The farmer hooked his tractor and gave me a nudge, that was all I needed to move on out.
I believe a hand push by two reasonable strong people would likely have been all that was needed in either mine or the OP's situation.
#38
Received 1,069 Likes
E55, GLS450, GL63, GLE350
You got that backwards. Too narrow is a problem in mud. You want wider tires in mud and low traction conditions. Tire flotation refers to spreading the weight out over the greatest area as possible so you don't "dig in."
#40
![](https://staticssl.ibsrv.net/autocomm/EvoM/fcotmicon.gif)
Received 3,404 Likes
2012 CLS63
#41
GL550
#42
No need to be nasty about it since it sounds like you can't drive. The fact that you said you floored the gas tells me that you're clueless about getting a vehicle unstuck in such a situation. Was just asking a question in the first place. You're the one looks like a fool getting stuck like that, since you wanna be that way about it.
M
M
#43
If the material in which you are stuck is too wet and soupy you will need to add some sort of material (ie kitty litter or even rocks... but if you gas it, that will fly at your vehicle. So keep that in mind)
I don't think the vehicle is the issue here. Once you got yourself stuck, trying to get yourself out the way you did was. My wife does it all the time.
#45
All other times, you want maximum pressure per square inch of tire contact.
Narrower tires most of the time provide best traction on wet, snowy surfaces because you DO want to "dig in," i.e. not aquaplane.
#46
Here is a truck with flotation tires.
http://www.ebay.com/itm/tractor-spre...item43a9dcd28b
http://landmaxcn.en.alibaba.com/prod...tion_tire.html
http://www.nextag.com/Flotation-Tires/shop-html
http://www.no-tillfarmer.com/pages/N...Make-Sense.php
Campbell says farmers in narrow-row applications may want to consider adding duals or triples as a way to create more flotation. He says this will help spread the load over a wider footprint. While many farmers will add duals or triples to the back axle, he says adding duals to the front of mechanical front-wheel-drive tractors is also becoming quite common.
#47
R63 AMG; CLK430; 240D; B200; E500 wagon 4Matic
#48
Nope, only time you want "flotation" is when the mud is bottomless. Or you're talking sand, which is, too.
Edit: In this scenario, a tire with a more aggressive tread would have worked better since it was just mud underneath. Cutting through the mud in the OP's case with street tires will do nothing but dig ruts as he did. Tire width was fine but the tread pattern was not since it filled with mud and allowed no traction.
After additional research, a tread width of around 265 to 275 MM for a GL looks to be the perfect width for a vehicle this size in most terrains. Wider is not always better in regards to traction with the exception of smooth road surfaces. Tall and aggressive tread design is what you want for mud and jungle type conditions with good spacing between the lugs so the tire will clear itself. Wide is best for the street, sand, and deep offroad snow, or deep mud. You want flotation tires if the surface is soft enough to sink past 110% of the vehicles minimum ground clearance.
Of course, recommended tire width is also product of the vehicles weight. A lighter vehicle needs narrower tires to have enough pressure per square inch of the tread to get acceptable traction in muddy conditions. As weight increases so does the need for tire width to acheive ideal traction. So to say that narrower is better is not exactly accurate but neither is saying wider is always better.
A wider, higher flotation tire is designed with a wider profile that helps the tire maintain flotation in wet field conditions, but also offers enhanced traction and cleaning due to the wider and deeper lug pattern.
#49
2008 GL 320 CDI Black/Black
Not sure anyone said this, but turning the wheel and moving as slow as possible may have brought the vehicle back on top of the grass and allowed it to coast out. The trick is slow. I've been driving on ice all my life - and in plenty of wet muddy fields - slow slow slow. The tire width argument is a good one. But I would tend to go with narrow on a smaller rim for the best traction. Wider is rarely right. You would displace more weight around the tires - but you would need 2' wide tires to make a real difference with 6000 lbs....and that's not an option. So wider for fast driving grip - but not traction.
#50
I was unstuck the next day and it was no big deal because I was camping and didnt even need to use the vehicle.
I've realized from reading other responses that my tires just turned to slicks with all the mud and the weight of the vehicle in the mud. All 4 tires were just caked with mud and all 4 spinning. What would have probably worked was the idea of putting gravel down under the tires or kitty litter, thats good to know for the next 50 years if I ever get stuck! I guess learning something new was the best lesson here.
