GL450 - big improvement swapped stock 19" for 22"
Old Jan 29, 2012 | 03:36 AM
accessdenied's Avatar
GL450
nice wheels...
How much did you spend on this setup? Thanks.
Wheels are 22X10 ET50 replica AMG wheels with gray colored accents and the tires are new Michelin Latitude 295/40/22 tires.
Before:
After:
[/QUOTE]
Old Jan 31, 2012 | 02:08 PM
ObssedOne's Avatar
GL450 CLS500
I bought them used from another member on the forum but they were originally purchased from ForMyMercedes
Old Jan 31, 2012 | 02:25 PM
GL450
how much are the used?
Old Feb 1, 2012 | 12:42 PM
ObssedOne's Avatar
GL450 CLS500
PM sent
Old Apr 4, 2012 | 06:00 PM
cmarshack's Avatar
GL450; Audi Q7 sline; GX470-SOLD, E55-SOLD, Range Rover Supercharged-Sold
Looks great!!! You also got the chrome door accents and got rid of that pesky kid climbing around inside
Before:
After:
[/quote]
Old Apr 4, 2012 | 06:57 PM
alx's Avatar
alx
Originally Posted by MRAMG1
Not true my friend. The higher pressure will make the rim bend EASIER.
Simple physics, high pressure, make the sidewalls stiffer, transmitting MORE force on the rim. Lower pressure allows the sidewalls to flex, absorbing the force
i just saw that.
wrong.
the rim bends when the tire bottoms out and there is nothing to give. the more pressure you run in the tire- the harder it is to "fold" all the way to the rim.
generally speaking you want road-tire-air-rim... rims bends when the sequence becomes road-tire-rim
of course jump in the "right" pothole and nothing will save your rim regardless of pressure. but higher pressure protects your rim better. the rule of the thumb is that for every inch additional tire diameter you want a 1.5 psi of additional pressure. thus if you run 18" stock and you go to 20" you want to go from say 33 to 36 psi
