GL450 rev up a little at each gear change when downshifting?
Old Nov 14, 2011 | 12:15 AM
dchou4u's Avatar
GL450
Talking GL450 rev up a little at each gear change when downshifting?
I got a 2008 GL450. Whenever I slow the car down using my brakes, I noticed that the vehicle will rev up a little whenever it shifts through the gears as it downshifts. Is this normal or does it point to a transmission problem?
Old Nov 14, 2011 | 07:02 AM
Mikeee's Avatar
2008 GL 320 CDI
Every car revs up as it downshifts. Lower gear requires more revs to maintain the same vehicle speed... the same way it revs down on up shifts.
Old Nov 14, 2011 | 11:33 AM
justthebest's Avatar
'09 SL Black, '12 ML63, '13 SL63, '14 E63 Wagon, '14 458 Italia
I wouldn't go so far as to say every car, but yes, totally normal.
Old Nov 14, 2011 | 11:47 AM
alx's Avatar
alx
if you pay attention you will also notice that the rpms slip a bit (100-200 rpms) higher when upshifting under light throttle.
