When I had my '07 GL450 I had the vizualogic headrest in but didn't have a 3.5mm jack - just the ipod interface. Had to purschase the AASS - I believe it became standard in the '09 so its what you have in your car now (its basically a Y with each input on either end). And yes, you do have to have the ipod unplugged in order for it to sense things coming thru the 3.5mm jack. What I ended up doing is buying an ipod cable "extender" and wiring it into the center console, that way at least it made it easier to swap between the two - its a pretty hard to plug in the ipod in the glovebox when you are driving!!!
