GL TRUNK WILL NOT OPEN
Old Dec 1, 2012 | 10:43 AM
Hfdafhx's Avatar
Pinto
Anyone have a fix to the trunk not opening manually ( inside or out of truck) nor with the door switch...
I hear the hydrolic pump trying to open but sound like the release latch isnt releasing
from reading the forums I hear #1 issue is the release not releasing.
Has anyone fixed it them selves?
Old Dec 1, 2012 | 05:46 PM
JimBarnhart's Avatar
2015 Ram 2500, former 2013 GL350, 2007 GL450
I haven't heard of this, but there's another post started on 11/27 on the same topic.
Old Dec 1, 2012 | 06:18 PM
Hfdafhx's Avatar
Pinto
i locked unlocked and played with the fob a few times then let it sit and it opened and works all of a sudden
thx
Old Dec 1, 2012 | 11:08 PM
refresher72's Avatar
2016 GL450
I had the same issue and got it fixed by the dealer for free under warranty.
Old Jul 31, 2013 | 03:20 AM
Cdngrl's Avatar
2007 GL450
What was the problem? How much was it to fix? I am having same issue with 2007 GL450.
Old Aug 10, 2013 | 12:33 AM
chistoso's Avatar
1998 E320 Wagon
I did this myself. It's the latch. Part # A 164 740 07 35 It cost under $250.00. http://www.everythingbenz.com/z/part...00735-mercedes
If it sounds like it wants to release but can't this will solve the problem. If the pictures worked you will see the culprit, (latch). The Black button is the beeper. I tried to disconnect it but the hatch stopped working when I did. I'm sure you can bypass the wiring somehow. I just put some tape over the hole and it is much quieter now. You will probably have to order some new plastic tabs. I broke about 3 in the removal process.
Attached Thumbnails GL TRUNK WILL NOT OPEN-dsc08062.jpg   GL TRUNK WILL NOT OPEN-dsc08063.jpg
Old Apr 30, 2016 | 07:57 PM
Edhamo's Avatar
Mercedes Benz GL350 x164 2011
What a joke for the price of this car.. ive had this issue also on and off and its very irritating. Are you sure its a part that needs to be replaced and not just a programming issue?
