Ignition hold position 3
Old Apr 27, 2013 | 01:53 PM
AmoMB's Avatar
S Class
Hi, I read that on the ML's you don't need to hold the key on position 3 until it fires up, all you do is move to position 3 and the car starts itself. Was this an optional feature on the GL or can it be configued via Star?
Old Apr 27, 2013 | 06:58 PM
Fourdiesel's Avatar
2008 GL 320 CDI, 2004 VW V10 Touareg TDI
On any of the GLs the start switch (whether keyless go of not) merely initiates the start sequence. Once contact is made all the other parts of the sequence are out or your control.
Old Apr 27, 2013 | 07:38 PM
alx's Avatar
alx
Most if not all of the newer mb vehicles are push- button start ready. What that means is that as mentioned before the key is just th initiator. Cranking is automatic and stops when the engine fires up. So all you have to do is twist the key to position 3 and let to (while holding the brake pedal). Cranking and starting sequence commences.
Old Apr 27, 2013 | 10:52 PM
N_Jay's Avatar
2019 WS222 S450 4-Matic / 2007 W211 E350 4Matic (Sold) / 2008 X164 GL320 CDI
I think just about every thing since the electronic keys were introduced worked that way.
I know the 2000 S did.
Old Apr 28, 2013 | 05:11 AM
AmoMB's Avatar
S Class
Thanks all
