GL320 no start at -10F. Cranks but loud whine from back (?fuel pump)
Old Feb 6, 2014 | 06:21 PM
anb957's Avatar
2008 GL320CDI
2008 GL320 CDI was parked outside last night in Denver. When I tried to start this AM it was -10F. There was a loud whine from the back of car which I think was the fuel pump and the engine just cranked with no fire.
Could this be fuel gelling with cold weather?
Any additive I should use?
Or is it more likely a failed fuel pump?
If so, is this an easy DIY or should I just get it towed?
Ashok
Old Feb 6, 2014 | 06:42 PM
G55K's Avatar
Ashok
It's the fuel. Diesel fuel gets thick when it's this cold. There are additives that will help.
I also live in Denver. Looks like it's going to warm up tomorrow. The GL should start right up. This weather sucks!
Old Feb 6, 2014 | 10:23 PM
alx's Avatar
alx
Your fuel has gelled. Do not crank of you will destroy low pressure pump in the tank.
Stanadyne additive is your friend.
Old Feb 7, 2014 | 07:22 AM
a2j's Avatar
a2j
2008 GL320CDI (310k), 2017 GLS450 (170k), 2024 Sprinter 2500 (40k)
Filling up with winterized diesel helps a lot during the cold winter months. Just saying
Old Feb 7, 2014 | 12:38 PM
anb957's Avatar
2008 GL320CDI
Smile
OThanks everyone. 15f currently and still with loud whine from fuel pump and won't start. Hope I didn't burn out the fuel pump but only cranked four total times for a short period each.
What conditions are required for the fuel to ungel?
Old Feb 7, 2014 | 12:40 PM
anb957's Avatar
2008 GL320CDI
Where do you get winterized diesel?
Old Feb 7, 2014 | 06:47 PM
anb957's Avatar
2008 GL320CDI
FIXED!!
Temp hit 42F this afternoon and it fired up nicely. Fuel pump noise is gone. Thanks for the suggestions.
Old Feb 7, 2014 | 07:14 PM
alx's Avatar
alx
gas stations are supposed to switch to winter fuel some time in october- november. however, the one you filled up at is suspect.
change station...
Old Feb 7, 2014 | 09:19 PM
N_Jay's Avatar
2019 WS222 S450 4-Matic / 2007 W211 E350 4Matic (Sold) / 2008 X164 GL320 CDI
Did you buy fuel out of the area?
Old Feb 8, 2014 | 12:14 AM
anb957's Avatar
2008 GL320CDI
I filled in Aurora, CO at the station near Target at 225/Alameda. It is a no name station.
I will religiously stick to Shell diesel from here on out.
Agree that this is most likely the result of a bad tank / non winterized fuel.
We have started the beast in temperatures nearly this cold a couple times without trouble. But it is garaged 99% of the time so hard to say.
Old Feb 19, 2014 | 05:37 PM
jonathankreb's Avatar
'98 E320 and '08 GL320
I recently had the same problem with fuel bought in Wichita Falls, TX, and temps around 0 Deg F. Gelled fuel, whining fuel pump. I got it to a garage, warmed it for a few hours, and it started right up. There are various additives you can put in your tank that claim to fortify it to -40 deg F. I used "Heet" for the rest of my recent trip to Colorado (about the time you were having troubles), and the GL started well every time. As I was researching my problem, I saw that unblended Diesel will gel at 17 deg F. Also heard that biodiesel will exaggerate the problem. I would expect I had both unblended fuel, and possibly some biodiesel in the mix as well, since I suddenly became aware that many of the stations in the north of TX have as much as 20% biodiesel int he mix.
