Anyone replaced a steering rack?
Old Jun 28, 2014 | 03:35 PM
d6lc's Avatar
GL450
Mines started leaking from where the shaft enters the rack.
Anyone replace one?, is it a reasonable DIY, any tips?
Old Jun 30, 2014 | 06:58 PM
Fourdiesel's Avatar
2008 GL 320 CDI, 2004 VW V10 Touareg TDI
Spendy! Mine leaks a little now. It has got to leak a LOT more fluid to make it worthwhile to make the change.
Old Jul 1, 2014 | 08:32 AM
d6lc's Avatar
GL450
So I did some research, looked under the car and got a quotefrom my Indy at around 6 hrs labor!.
Looks like you have to remove the front axles , then the frontdifferential/drive to give you space to then remove the steering rack.
Started it last night, first issue was/is cracking the axlesour of the hub, 6 Minnesotan winters have done their very best to rust those 2together, count every hammer them free. So today they are soaking in liquidwrench, and I hope that I can strip the brakes off and get a puller on them tocrack the joint.
If I cant crack it then I guess the only way to get it out(passenger side) will be to pull the lower suspension out with the hub andaxle.
My indy wanted $2,200 for the complete job with an MB rack,I’ve ordered a rack from Napa at $600, so I’ll update how it goes.
I am sure it will be a long winded job, but we have a longweekend coming up and saving $1,500 is worth it in my mind.
I’m terrible at taking pics whilst I work, I’ll try andremember to do so, and at least I’ll do a written post.
Old Jul 1, 2014 | 08:34 AM
d6lc's Avatar
GL450
sorry about the terrible spelling, must use read it first before sending, and even better type it on my laptop, not Ipad!!
Old Jul 8, 2014 | 04:11 PM
C230 Sport Coup's Avatar
C230 Sport Coup + 2006 W164 ML350 + 99 Ford Escort RIP
Need to do this also. Please continue to update the thread.
Sad thing I just had all that out to replace the front diff bearings. Arrgh!
Old Jul 8, 2014 | 04:27 PM
d6lc's Avatar
GL450
I just did a separate post with a written DIY, it wasnt that difficult to replace just time consuming
