2011 GL450 Bulb -> LED replacement chart
I'm trying to replace original bulbs with LED, here is my chart. Please help me to find the missing one and share your findings.
#1 - Daytime Running Light It took me a while to figure out how to turn it on. There is a settings in the menu. Light stays On during daylight, Off when the main headlight is on.
#2 - Fog light - manual switch, Does it make sense to replace it with error free LED? Have anyone tried it?
#3 - Marker light - , works fine and looks great.
#4 - Parking light - , works fine and looks great.
#5 - Turn Light - , I'm thinking of buying this one. Let me know if you have a better one.
Thank you for your answers.
StudioAB
I have not replaced the Daytime running lights with LEDs but do know they use a H1 base type bulb.
Thanks for your list, I am interested in going with the led parking light. Was it hard to get to?
<<<@!1!@>>>
This is not correct.
I spent a couple hours today and found out that DRL original bulb is actually a PSX26W (Philips) bulb, so I ordered this LED replacement
Will keep you posted.
H1 actually is a fog light bulb and it also can be replaced with LED but it has to be used with external resistor which is a little bit overkill.
Amazon.com: 2 PCS Bright White P13W / PSX26W / SH23W 18-SMD 5050 LED Headlight Bulbs For Driving Fog Light / Day Time Running Light DRL: Automotive
09' GL550, 05' S55 (sold), 04' Yukon Denali XL, 05' 745il (sold), 01' 740il (sold)
#1 - Daytime Running Light LED replacement It took me a while to figure out how to turn it on. There is a settings in the menu. Light stays On during daylight, Off when the main headlight is on.
#3 - Marker light - Error Free LED, works fine and looks great.
#4 - Parking light - Error Free LED, works fine and looks great.
#5 - Turn Light - Error Free LED, I'm thinking of buying this one. Let me know if you have a better one.
You can see photos in this thread
For DRL i used this
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
For Front Marker light
For Front Parking light
Read more: https://mbworld.org/forums/gl-class-...#ixzz3IY3MFJfr
For DRL i used this
other PSX26W options?
For DRL i used this
For DRL i used this
I read the reviews on Amazon on the DRL LED bulbs you indicate, and they're pretty horrendous. Alternatively, I found these PSX26W bulbs that appear of higher quality:
http://www.kbcarstuff.com/PSX26W-Xen...psx26w-led.htm
