Level control malfunction
John
Might very well be a failed compressor. And that can be caused by overheating created by an air leak.
John
I used my MB II to clear the codes in the airmatic module and I could cycle the ADS to any of the three settings afterwards. The message still appeared in the cluster. I'd have to do the same every time I started the truck.
Replacing the ADS module which is mounted on the shock resolved my problem.
You would get this behaviour if your harness was disconnected from the ADS midule on the shock too, or if your harness wires were broken. The point I'm trying to make is that there are several causes to this. I would ask the dealer for a copy of the codes they pulled when they diagnosed. It should give you an idea about where the problems may lie.
If they've replacing shocks, they're also replacing the ADS modules mounted on the shocks. These modules can be replaced by themselves as they're mounted to the shock via 2 screws hidden under thick rubber grommets. Replacing just the modules is less work than the rear shocks. For the shocks you'd need to remove interior panels which is probably an hr of work for each side.
P.S. wow, I just wrote a mini novel to reply to posts from 2015! Not paying attention - check!
