Decided to change wheels, need advice on size
1 Post
09' GL550, 05' S55 (sold), 04' Yukon Denali XL, 05' 745il (sold), 01' 740il (sold)
All,
After much research and thought I decided to change my wheels from 21" because of the outrageous cost of tires which have short lifespan and limited choices. This would give me a wider range of tire to choose from and cost will be more tolerable.
the question is should I go:
- 20"x10" replica
- 22"x10" replica
and which vendor is the best to get these wheels from. I need them to be hubcentric.
current vehicle info:
Vehicle: 2009 GL550
Wheel size: 21"
Please advise...
- 20"x10" replica
- 22"x10" replica
Vehicle: 2009 GL550
Wheel size: 21"
Please advise...
1 Post
Next question is about tire size.
can i run 295/50/20 or 305/50/20 on a 20x10 et50 without rubbing in the front?
they are recommending 275/50/20 or 285/50/20, my fear is that they will look skinny and not flush on a GL550 especially with the flares.
The 295/40/21 already is not flush with the fender so i can imagine the 20" with a 50mm offset.
need some advice...
1 Post
Great, I was trying to get them thus weekend but formymercedes.com only seem to have the style I want in 22".
wheeltechtuning says they will call me back on monday to get proper fitting.
anyone with other seller you recommend that is reputable?
1 Post
just bought:
20"X10" Replica
Tires:
i also bought 285/50/20 yokohama parada spec-x.
Now i have to think about moving my TPMS from one wheel to the next.
How easy is it to reprogram if I buy a new or used set?
20"X10" Replica
Tires:
1 Post
I received the tires today, and another surprise, I received the "air suspension malfunction error"
Here are some picts of the yokohama, i went with 295/45/20, looks wider than expected.
Our GL420 came with 22" after market rims and they do look boss but we do a lot of towing (worried about pot holes and ride quality). Haven't really noticed any mpg drop on the 22's to be honest but I don't look that closely.
We use our GL in two modes effectively long range towing or short range school runs.
Where did you source your tires from?
When buying our car I managed to negotiate getting the original 19" wheels as part of the sale and swap between them when towing or in the winter.
1 Post
I bought mine from Tire rack, I bought 285/50/20 but I was told 295/45/20 is a better fit and also more aggressive.
My GL went to the shop this morning for the air suspension issue.
The wheels are coming today, hopefully i will have everything on early next week.
