GL450 airmatic to coil spring conversion kit
Old Jul 20, 2019 | 11:47 PM
jimmytran2411's Avatar
Gl450 2007
Originally Posted by refresher
Hello All-
I just replaced air springs on my 2008 gl450 for the SECOND TIME..
I am wondering if anyone of you used or heard of "Suncore conversion kits for airmatic"?
http://www.suncoreindustries.com/Mer...ersion-kit.php
I love my GL but the airmatic issue is putting me off..So, I still want to keep my GL but see if I can switch to coil springs if found it to be a reliable alternative..
Please advise
Gary
I ve order one and replace to my air spring. That is perfect nad smooth but hard to install the rear back. But it worth to change
Old Aug 6, 2019 | 04:04 PM
justinwrock's Avatar
Ducati
If you don't do much towing, you should be able to convert to steel spring suspension quite easily using MB OEM parts.
All of the mounts and pickup points are the same between airmatic and steel spring, so it would just be a matter of picking up shocks appropriately matched to your configuration.
Look up a 2007 ML320 CDI for shocks to get an idea of the varying range - you'll be able to piece together a kit with better components than one that's preassembled.
Old Aug 8, 2019 | 04:38 PM
Max Blast's Avatar
NGL450 w/EORP, S550
Old Aug 8, 2019 | 04:40 PM
Max Blast's Avatar
NGL450 w/EORP, S550
Originally Posted by Lee Reed
I just wish I could easily switch off the Airmatic malfunction message that reappears at every startup.
If you have an airmatic malfunction message something else is wrong. Harsh ride won't trigger that message but out of spec ride height, a compressor that isn't on when it's being commanded to, will.
Have you checked the compressor fuse and relay?
Old Aug 9, 2019 | 01:15 PM
Ducati
It's frustrating when the original poster doesn't reply, so here I am! The rear springs I bought off Ebay and they were from the ML. I worried that the heavier GL would sag or be harsh, but there's been ZERO issues with ride quality on the rear. I paid a mobile mechanic just under $200 as I recall, to swap out the rear airbags for the coil springs...it wasn't a DIY in my eyes.
As for the fronts, I paid a different mechanic, a few months earlier, about $170 to swap out the fronts. I'm less happy with the front coil struts from Suncore, because they are harsher on bumps, and I think the front sits lower than ideal. I'm still happy overall. I just wish I could easily switch off the Airmatic malfunction message that reappears at every startup.
Occasionally I miss the functionality, but I have no real regrets at swapping over. I'm still under 100k miles on my 2007, so it could have a long, long life. I -may- look into whether there's a way to adjust the front ride height, but it doesn't keep me up nights, worrying about it. In a little while, I'll post some photos. Wow, my id was quick sending me the pics. I guess it's not as low in the front as I realized. Anyway, every Sunday morning it's filled with 7 people headed to church, and zero complaints on ride quality. I plan to remove and sell the newish airmatic compressor. That'll be a weight savings.
Where are you located? I've coded the error message out on a W211 and think I can do it on a W164 fairly easily. You might also be able to unplug the airmatic computer for the error to go away.
You should be able to use front strut cartridges from any non-airmatic equipped W164 if you're interested in changing the ride quality. Bilstein, Sachs, and a few others make different options.
Old Aug 11, 2019 | 09:22 AM
gl786's Avatar
GL320
I was thinking of this the other day, why can’t a ML series springs be used & was feeling silly to ask this question. But it is great to know that there is a possibility.
Old Aug 25, 2019 | 05:43 PM
  #32
Lee Reed's Avatar
2007 Mercedes-Benz GL450
I'm in the Dallas area in Texas. Does that help?
Old Aug 25, 2019 | 05:44 PM
  #33
Lee Reed's Avatar
I do have one of the ride height sendors disconnected. I will start by plugging it back in. Good point.
Old Dec 16, 2019 | 10:27 PM
  #34
Lee Reed's Avatar
FYI, I did NOT have to switch out shocks when I converted to coils.
Old Dec 16, 2019 | 10:29 PM
  #35
Lee Reed's Avatar
Remember, I'm the guy who converted from Airmatic to coil springs. There's DEFINITELY a good reason for the error message, LOL.
Old Feb 17, 2020 | 09:31 AM
  #36
Daniel123's Avatar
2010 GL450
hello am having problems with my 2010 GL450 the front driver side drop down low when parked, is that compressor bags, is it safe to do the conversion kit, will a message come up on dash and stop it from passing inspection ? thank you
Old Feb 17, 2020 | 04:35 PM
  #37
BlownV8's Avatar
E55, GLS450, GL63, GLE350
Will be wat cheaper to fix. Look on Amazon or ebay. I think I found a complete replacement strut with airbag for $150 a little while back.
Old Feb 17, 2020 | 09:08 PM
  #38
Max Blast's Avatar
NGL450 w/EORP, S550
these china bags/struts are utter crap, made to last only as long as it’ll take you to sell the vehicle.
there is no reason to not buy arnott or Bilstein airbags for the x164, as arnott gives you free replacement bags for as long as you own the vehicle.
This lifetime replacement also makes coil spring conversions pretty moot imho.
Old Feb 18, 2020 | 08:27 AM
  #39
BlownV8's Avatar
I have not had any issues and the strutt it replaced was a RMB that failed. When your vehicle already has 250k miles, I'm not thinking of driving it another 250k miles though I think it would be just fine.
Old Feb 19, 2020 | 01:02 PM
  #40
Daniel123's Avatar
2010 GL450
I don't think am going do the conversion kit on the GL450, question when front driver side lean down when you park some times then go back up when you start, is it the compressor or the air bag. thank you
Old Feb 19, 2020 | 01:25 PM
  #41
CharlzO's Avatar
2010 GL550
Usually the bag is the culprit, so it's the first thing you'll want to check, and then work your way backwards from there.
Old Feb 21, 2020 | 09:48 PM
  #42
eric_in_sd's Avatar
2007 GL450
It is a mystery to me why anyone would go cheap when there is all this labor and inconvenience involved, and you can get high quality backed by the best customer service I have ever encountered.
Arnott. Literally no other.
Old Feb 22, 2020 | 12:47 AM
  #43
BlownV8's Avatar
I've used Arnott, RMT, MB, and the cheapest version. So far, RMT and MB OE are tied for the lowest ranking in terms of longevity. Arnott is good but I did have a strut fail. They promptly sent me another. Labor to replace the front struts is cheap and, if I keep my car long enough, will let you know how it turns out. So far so good. With 250k miles, not sure how much longer I will keep the car. Still runs great, handles great, and is very comfortable on the hwy.
Old Mar 2, 2020 | 10:24 PM
  #44
Dinismb's Avatar
2005 Mercedes C230 Kompressor, 2008 GL 320 CDI, 2008 ML320 CDI, 2016 GLE 300d AMG Night Package
hey buddy how did you get rid of the Airmatic error message on the dash?
Old Apr 29, 2020 | 06:14 PM
  #45
Riki Novi's Avatar
GL 450
Hi i just bought a GL 450 2007 year model from Iaai car is sitting low I want to do the same conversion that you did picking the front and rear shocks and springs from a w164. I was a little confused about this becouse i didn’t thought they would fit.
Occasionally I miss the functionality, but I have no real regrets at swapping over. I'm still under 100k miles on my 2007, so it could have a long, long life. I -may- look into whether there's a way to adjust the front ride height, but it doesn't keep me up nights, worrying about it. In a little while, I'll post some photos. Wow, my id was quick sending me the pics. I guess it's not as low in the front as I realized. Anyway, every Sunday morning it's filled with 7 people headed to church, and zero complaints on ride quality. I plan to remove and sell the newish airmatic compressor. That'll be a weight savings.[/QUOTE]
Old Apr 29, 2020 | 06:59 PM
  #46
eric_in_sd's Avatar
2007 GL450
Good for you. Glad it worked out.
I couldn't believe it. I sold my compressor on Ebay for ~$50 plus shipping. Had 140K miles on it. Now, I never abused it - never limped along with leaking springs - but still I'm impressed. Better than chucking it in the landfill, plus I got me some beer money out of it.
Old Aug 25, 2020 | 01:55 PM
  #47
Larry Slate's Avatar
GL450
Hey Fireman1073. Are the rear bags as simple to swap out and are they the same item number?
Thanks.
Old Oct 20, 2020 | 05:15 PM
  #48
nuguy93's Avatar
GL450
I did the suncore kit on my '07 GL450. I'd bought and DIY'ed a new compressor, which didn't fix my problem with varying heights at the corners. In hindsight it was the distribution block (I forget the technical term for it.) I decided to never deal with the problem again and convert to coils. I paid a total of $375 labor to do swap out all 4 corners to coils. Turns out 3 of 4 airbags had been replaced over the life of my truck, which I'd bought in 2015 with 66k miles. Now we are back to smooth riding with coils and no more airbag worries. In hindsight, I should've made sure to get the extended warranty when I bought this SUV.
Just did the SUncore kit on my wifes 2008 GL and wondering how to turn of the dash warning light. Can you advise? Thanks in advance.
Old Feb 11, 2021 | 10:12 PM
  #49
Chacho Aquino's Avatar
2008 gl450
How is your ride.
sorry for bringing old topics up but I would like to know how did your conversion end up? Is the ride good ?
Old Mar 25, 2022 | 07:17 PM
  #50
Chaddydsm's Avatar
2011 GL450
DONT DO THE CONVERSION
Originally Posted by massimobenz
Hi .... thinking of doing the same thing. I'm sick of the issues and want to avoid long term maintenance. How's the ride so far? Do you notice any difference. Is the ride the same?
I just had it done and completely regret it. Have a 2011 GL450 we’ve driven all over the country. Replaced air springs a few times, decided to do coils because I intend to drive it forever and cost over time appears less for a guy like me that doesn’t work on his own car. Had strutmaster conversion done - Car rides like a tank now. I’ve had warning lights, sensor problems, you name it it’s been a nightmare since they took out the air springs. Reliable mechanic in the past, swing and a miss on this one. I’d trade it straight up for an old Prius at this point. Loved the GL for years, the coils made it a tank with nothing but problems. Pay the money to fix the air springs.
