Power Steering leak fix?
Old Dec 17, 2015 | 10:27 AM
refresher72's Avatar
2016 GL450
My 2008 gl450 has a leak from the steering rack... Mechanic says need to replace the rack and pinion assembly. Please advise if that is the only option or replacing the power steering hose O rings wld do it? How many hrs of labor it takes to replace rack and pinion? Any recommendations on remanufactured rack and pinion? Which is beteer aftermarket r&p MasterPro (O'reilly) A1Cardone(Advanced auto)?
Please review the uploaded leak pics for reference
Attached Thumbnails Power Steering leak fix?-img_1402.jpg   Power Steering leak fix?-img_1401.jpg
Old Dec 17, 2015 | 01:48 PM
BlownV8's Avatar
E55, GLS450, GL63, GLE350
Make sure it is not coming from the power steering reservoir since they are known to leak.
Old Dec 24, 2015 | 01:10 PM
racebmwm3's Avatar
2010 GL450
Leak looks like it is coming from up high. I would take a look up top and examine the reservoir/hoses before replacing the rack.
That said, my rack is leaking slightly (not as bad as yours) but it definitely seems like it is coming from the left seal.
Old Dec 26, 2015 | 09:34 AM
mike278's Avatar
2011 GL450
Not going to swear to it, but I believe there was a TSB to replace the hard lines and o-rings on the racks of some MBs. Might save a few bucks over a whole rack.
Old Dec 26, 2015 | 09:48 AM
joshd2012's Avatar
2008 GL320 CDI
I had the same issue and MB recommend the same thing - replace the rack. Fortunately, I had it covered under extended warranty. IIRC, it was five hours of labor and they also shook me down for an alignment.
