Help tailgate issue!!!
Old Feb 21, 2016 | 05:34 PM
Timdunivent's Avatar
2011 GL450 4matic
Hello this is my first post so go easy on me, I have a 2011 GL450 that I recently purchased and the tailgate will not latch unless all the doors are closed. If any door is open it just reopens the tailgate immediately after it closes without latching
Old Feb 22, 2016 | 07:30 AM
mike278's Avatar
2011 GL450
Before you dig too deep into the diagnostics, pull the switch out of the rear hatch. It just pops out with a plastic wedge. Unplug the electrical connector on the back of it. Check the pins on the switch for corrosion. Spray the pins with some electrical contact cleaner. My wife's 2011 was doing weird things because the switch tends to collect water in the connector. Hope this helps.
Old Feb 22, 2016 | 02:38 PM
2011 GL450 4matic
Thank you I will try this out today
Old Feb 28, 2016 | 05:24 AM
markir's Avatar
GL 320
Not sure if the 450 has the same latch but my gl320 had a rear door latch fail and at the time we discovered they were known to have a problem.
