Ac problems code 9006
Old Aug 27, 2018 | 09:31 AM
machadosl's Avatar
1999 E240, 2007 GL500, 2004 Suburban Z71, 1997 Ford Escort MK7, 1979 VW Beetle
Well, considering you ha installed the same control valve that was on the old compressor I think making a reset or reprograming with Star Diagnosis it is going to clear this fault unless, you have a short somewhere else.
Old May 20, 2019 | 06:59 AM
Suresh Yadav's Avatar
Ml 350
I Need help regarding code 9006
Uhave solution! Then plz help
Old May 20, 2019 | 10:57 AM
Vss's Avatar
Vss
w164
Old May 20, 2019 | 11:00 AM
Vss's Avatar
Vss
w164
The Second way !
Old Jul 29, 2019 | 08:56 AM
dagentooboy's Avatar
2008 GL320
FYI the wire on mine was blue with green stripe instead of violet with black stripes on a 2008 GL320. If you can get to the A/C connector you should be able to pull the sleeve back a little bit and make sure. Just be careful. The first wire I tried to put my DMM on killed the engine as soon as I put the DMM on it. Make sure you have the right wire before you start cutting into the wires.
Old Aug 19, 2019 | 10:20 PM
edvaru's Avatar
2009 gl320
2009 GL320
I also experienced the AC coming on and off randomly for no apparent reason. My code reader said error 9006 compressor short circuit. I can confirm that 2009 GL320 also has blue/green wire for AC compressor. I installed diode as shown and have no issues so far. Thanks for your detailed pictures.
Find blue/green wire
Install diode
Old Aug 22, 2019 | 09:37 PM
  #32
wrightbenz's Avatar
SL55 SLK 320
So this is an odd issue. It does work but my situation was a bit different. My ac clutch or really just a pulley since these ac compressors never disengage. It’s more like a dampener than a clutch. At any rate there is a bearing in there and mine was making a ton of noise. I decided to just try and replace the clutch/dampner with the compressor on the car. I figured this would be easier than opening up the system for a compressor swap. Well I did manage to change the clutch with the compressor on the truck. This is 2011 gl450. Problems arose though. The ac clutch short error came up and **** down the ac control valve. I have no idea why this happened since the new clutch has no electrical component. So I ordered a new compressor and just for the heck of it some diodes. I installed the diode just as described here on the top of the engine and my ac worked again. I will keep the new compressor because this way I will never have it fail Murphy’s law.
Old May 16, 2020 | 07:18 PM
  #33
EWT's Avatar
EWT
11 ML550, 95 Supra TT, 14 Audi S4
Here's the wire in question on a gas engine (GL 550 in this case). It is by itself inside a ribbed rubber cover that comes up from the compressor behind the power steering reservoir before joining a bunch of other wiring into a common cover on top of the valve cover:
The cover was cut to access the wire
1N4007 diode is inside the black shrink wrap and soldered to the A/C signal wire
Old Jun 27, 2020 | 05:27 PM
  #34
fearzum's Avatar
R550
Talking Awesome
Added the 40 cent diode and saved a $1000. Many thanks for sharing this. It could have turned into an expensive proposition. 2008 Mercedes R550.
Old Jun 28, 2020 | 09:08 AM
  #35
S-Vibes's Avatar
2010 GL350 BLUETEC, 2013 E350 Sport
Fingers crossed
Diode ordered from eBay 10x for $1.78! Can’t wait to get them and give this solution a try. If this works, this may be my biggest $$aved by searching this forums for solutions.
Thx all for sharing knowledge, especially @Vss
Old Jul 31, 2020 | 06:26 PM
  #36
Iliana_Omar's Avatar
GL450 - x164
I’m doing this same repair ,
could you pm more precise instructions on to where and how to connect the diode , I have everything it’s just that I’m way too much of a visual learner and do appreciate the pictures
I have a 2010 GL450 , I found the blue,green wire , I’m totally lost where to disconnect to get the diode solderized and reinstall
Originally Posted by EWT
Here's the wire in question on a gas engine (GL 550 in this case). It is by itself inside a ribbed rubber cover that comes up from the compressor behind the power steering reservoir before joining a bunch of other wiring into a common cover on top of the vale cover:
Old Jul 31, 2020 | 07:03 PM
  #37
S-Vibes's Avatar
I’ll solder it eventually, but just for now I used a quick connector. Don’t ask me about the stupid magnets the previous owner put on the fuel line😖
Old Jul 31, 2020 | 07:58 PM
  #38
EWT's Avatar
EWT
1. Strip a short section of insulation on the blue green A/C wire to expose the wire inside.
2. Wrap a couple of turns of the cathode end of the diode around the stripped blue green wire and solder
3. Solder a short section of wire to the anode end of the diode, put a ring connector on the other end of the wire and connect to a ground.
4. Use shrink wrap and/or electrical tape to insulate anything that is uninsulated.
Old Aug 1, 2020 | 10:23 AM
  #39
GL450 - x164
Same issue
Im reading 5 bars , fans don’t kick in when compressor is on , just did the diode soldering still no cold air , how ever no leaks still has freon
Originally Posted by bbspoolside
All fuses are ok, the cooling fans kick on when I activate Ac thru sds and have 10 bar pressure on low side and goes up to 16 bars running. This is the second new compressor I have fitted both with the same code. The first new compressor I removed and fitted to another car and is working perfectly on that car. am at a loss as what to do next
Old Aug 9, 2020 | 01:01 AM
  #40
lawrencenef's Avatar
1999 Mercedes Benz ML430 & 2008 R350
Hello friend. Would you please help me, by telling me the colors of the ac wires that I need to install the diode, and where I can find them on my 2008 R350?
Old Aug 9, 2020 | 07:05 AM
  #41
S-Vibes's Avatar
There are literally pictures in this thread that do just that. If you’re still confused, then take a pic of your wires and post it here and we’ll help you pick out the right one.
Old Aug 9, 2020 | 08:59 AM
  #42
Grateful
Thank you. I checked the thread and don't see the correct color of wires for my 2008 R350. I see other models. If you come across the correct color code for an 08 R350, please respond. I'm a grateful student and you're my mentors.
Old Aug 9, 2020 | 09:03 AM
  #43
S-Vibes's Avatar
Respond with the requested picture of the wires in your bundle, and you will have an answer very quickly
Old Aug 9, 2020 | 09:08 AM
  #44
Help please
Hey man. I have a 2008 R350. The ac kicks on and immediately fades off blowing humid warm air.
Would you please send me pics and/or all information on how you were successful and Victorious, installing the diode. Also, PLEASE let me know the color of the correct wires. I'm a grateful student and I appreciate your mentoring me on this great opportunity to do what you did. Freakin awesome!
Your diode install probably saved you $3,000. Please assist a guy in need to help his family stay cool. The humidity activates my passengers Asthma. I'm in The Bronx, NY, and i'ts HOT!🔥🙏🧡👍🇺🇲🇺🇲🇺🇲💪
Old Aug 10, 2020 | 04:32 PM
  #45
OK
OK S-VibesS- I'll get back to you asap.👍
Old Aug 19, 2020 | 07:11 AM
  #46
The_Pharoah's Avatar
2008 ML 350 4Matic
Hi, Can you share the solution with me please? I have codes 9006 and 9103. 2008 ML350 4Matic
Old Aug 20, 2020 | 05:03 AM
  #47
S-Vibes's Avatar
It's not really that long of a thread, I would think someone with a problem would just read it, but if that's too much trouble: Just read 28-31 and 33-37.
Old Oct 2, 2020 | 06:13 PM
  #48
EmilyMB's Avatar
gl550
I added diode 1N4007 (same as yours) to my 2010 GL550 with original AC compressor. It did not work. Should I try different diode 1N5817 or ....?
Old Oct 2, 2020 | 06:18 PM
  #49
EmilyMB's Avatar
gl550
AC works ice cold only weather 75 and below...please help if you have any ideas.
Old Jan 23, 2021 | 03:30 PM
  #50
Mikail Na's Avatar
ML W164 OM642 320CDI
Originally Posted by Vss
i have solution! if you have fault code 9006. it's very easy to fix it. send me private message.
hello, friends have the ml w164 bj2009. I have the problem with ERROR CODE 009006 too. air conditioning works sometimes and sometimes not. With me under the bonnet everything looks different. I can't find the cables for the diode to attach 1N4007. engine code om642
