2008 GL320 - STEERING COLUMN ADJUSTMENT
Old Jul 20, 2016 | 10:22 PM
jenxo's Avatar
GL 320 CDi
Howdy,
Recently got a nice used GL320. Time to fix minor annoyances.
The Steering column adjuster moves the column FORWARD and BACKWARD ( in and out), but NOT up and down. I hear Motor noise, but it doesn't move.
Fuse or replace motors or ?
Advice requested.
-Jenx
Old Jul 21, 2016 | 12:49 PM
alx's Avatar
alx
"or"
if you hear motor noise... it is the "or"
i hate steering columns with a passion... expensive, hard to troubleshoot... etc.
Old Aug 8, 2016 | 10:49 AM
a2j's Avatar
a2j
2008 GL320CDI (310k), 2017 GLS450 (170k), 2024 Sprinter 2500 (40k)
Sounds like a broken coupling. I have the same issue. As far as I know, you can't just get that part and replace it.
Old Aug 29, 2016 | 08:46 PM
entersandman's Avatar
W205, X164
Hello folks,
I have a somewhat of a similar issue as the op reported with my X164 : anyone else encountered this?
The steering column bracket assembly, that has the turn signal, gear shift, cruise and steering adjustment levers, has rotated counter-clockwise about 25 degrees. No problems in using any controls, everything works as expected, it's just annoying to have the turn signal lever so down low that i keep hitting it with my knee and activating the wipers. Not to mention so many times I've hit the cruise control as it is now in the position where turn signal lever should be.
The bracket itself is not loose or wiggling. It's tight but seems to have rotated so far left.
Dealership wants to change the whole steering column... imagine my shock.
Any ideas?
Thanks.
Old Aug 30, 2016 | 03:17 PM
alx's Avatar
alx
the collar has slipped. somebody likes grabbing stalks full- fisted. lol.
this is actually not a complicated fix. unfortunately, due to litigation risk the dealer will not get involved with fixing it, but rather replacing the whole column.
