Amazon source for MB approved bearing grease - and quick bearing question
Old Aug 17, 2016 | 09:09 PM
andrewjoseph's Avatar
2012 gl 350
After searching for some time on here for a source for Mercedes spec bearing grease, I looked up their list of approved grease from other manufacturers and found a decent one on Amazon Prime. The only issue is you need to by a case of 10 tubes at $24.99. Each tube is 12oz, so this is many times cheaper than purchasing the small 150g tubes from the other online retailers.
Its Chevron Starplex EP2, heres the link:https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
Also, I have never seen a bearing like the one I ordered for my GL350. Admittedly, I have only seen two other bearing for an older car. Is this a sealed bearing that does not require packing, or is there a way to separate the bearing and pack in grease?
Thank you for the help on bearing, I know this is a basic question. I found a shop to remove old one and press in new on tomorrow. This is the bearing for the right front that I purchased.
Thank you.
