front knocking noise
Old Nov 1, 2016 | 08:03 AM
a2j's Avatar
a2j
2008 GL320CDI (310k), 2017 GLS450 (170k), 2024 Sprinter 2500 (40k)
It sounds like worn out sway bar links, but I replaced those couple of months ago, so it is not that. Issue started 2-3 weeks after I replaced those. I also feel it in the steering wheel. Replaced both tie rod ends and problem still exists. What should I check next?
Old Nov 1, 2016 | 09:01 AM
DennisG01's Avatar
'08 GL 320 CDI
Don't count out the sway bar end links just because they were replaced recently. Check them out - especially if they are cheapies. I'm relatively new to this GL320, but it seems like end links are a pretty common thing to wear out quickly. But hey, I'll take that (easy, cheap) over something else!
I even had a knocking that we swore wasn't the end link - I couldn't manually make it make noise with the car in the air, neither could my shop. But everything else checked out so they made an educated guess and replaced it... yup, it was bad.
I also have a very small, occasional knocking noise that sounds more like it's from the the steering wheel shaft, down low (and can feel it). They checked that out and said there was an issue with it (not safety related), but to wait until it's more obvious so they can fix it under warranty.
Old Nov 1, 2016 | 09:20 AM
a2j's Avatar
a2j
This time I installed OEM to see if they will last more than the cheapies.
Old Nov 1, 2016 | 09:30 AM
DennisG01's Avatar
'08 GL 320 CDI
I'm wondering that, too. Considering even the OEM's go out kind quick, I wonder if it's worth it? I dunno.
I've got one Vaico brand on there (it's what the inspection shop had in stock) and another brand on the other side... I forget the name - sounded kinda German and I recognized it, but I forget. All within a couple months of each other. Next time, if I can plan ahead, I'll try Lemfoerder.
Old Nov 1, 2016 | 05:39 PM
alx's Avatar
alx
Yes, I have done quite a few non- oem swaybar links. They last about a month.
Oem is the only way to go for those. The pass side cv joint is also a hit or miss with aftermarket.
Old Nov 2, 2016 | 07:16 AM
a2j's Avatar
a2j
Two of my non-oem sets lasted 12-16 months. But with this oem set I'm loosing faith. I suppose I could get another set to see if it fixes current issue. If it does not, I'll keep it till I need to replace them. I still don't know how to explain the fact that I can hear and feel knocking on my steering wheel.
Old Nov 2, 2016 | 09:05 AM
DennisG01's Avatar
'08 GL 320 CDI
ALX, do you happen to know who makes the OEM set?
A2J, I can't tell you exactly what they did to diagnose the small clicking noise/feeling I have once in awhile in my steering wheel. But I can tell you that it didn't take them that long to diagnose it. All I remember on that is that it was something down low on the steering wheel shaft (although I could be using the wrong term there).
Some things I'm very comfortable doing myself, but I have never ventured into this before so I let them do it. If it's not something you're comfortable with, it might be worth it to let a shop take a look.
Old Nov 2, 2016 | 10:55 AM
gl450x164's Avatar
gl450 530i
Lemfoedor is the oe supplier
Old Nov 4, 2016 | 10:39 AM
a2j's Avatar
a2j
I might have two different issues here. The steering issue concerns me most. I also forgot to mentioned that when I quickly turn the steering wheel, while stationary, I hear and feel a knock sound. Steering does not feel loose or any different than before. But it feels like it is hitting metal on metal.
Old Nov 4, 2016 | 11:01 AM
gl450x164's Avatar
gl450 530i
Check your front axles
Old Nov 4, 2016 | 03:15 PM
DennisG01's Avatar
'08 GL 320 CDI
I can sometimes get mine to do the same thing. It never really feels like a "heavy" knock/clunk, though. More of a light sounding/feeling tick/clack.
Old Nov 6, 2016 | 07:09 PM
a2j's Avatar
a2j
Discovered the cause of the steering knock. Driver side bushing on the steering rack.
Did anyone replace those? Quick search shows 2-piece bushing per side. Sold in sets of 4, for both sides.
Old Nov 14, 2016 | 10:32 AM
a2j's Avatar
a2j
Old Nov 14, 2016 | 11:06 AM
DennisG01's Avatar
'08 GL 320 CDI
What a difference - those two are really chewed up!
Old Nov 14, 2016 | 12:03 PM
sak335's Avatar
2012 GL 350
I've got a similar knocking sound that didn't go away with replacement of the anti-roll bar end links (I used Lemforder...) and it's making me nuts. Before the car was out of warranty I took it to the dealer and they said they couldn't hear it. I can hear the noise with punk rock at full volume, so maybe they need their hearing checked.
Do you have part numbers for these so I can locate them and check them out on my vehicle please?
Old Nov 14, 2016 | 01:29 PM
a2j's Avatar
a2j
164 460 00 29
Old Nov 20, 2016 | 08:24 PM
sak335's Avatar
2012 GL 350
So I got under the vehicle today and found the bushings you show in the photo. I put a pry bar on the rack and can't get it to play at all, but the noise is just as you describe as is the feeling in the steering wheel. I'm only at 53k miles...
Anyway, my 3 year old was "helping" and I didn't put it on the lift so was just laying on my back, but it appears that the front diff is in the way of the bolt that you need to remove to swap the driver's side out. Can you explain how you did this? My only thought was that perhaps the bolt will clear the subframe hole if I push it through as far back as it will go, and then if I unbolt both the drivers and passenger side, then perhaps I can move the rack enough to pull the bolt and swap out the bushings.
My driver's side bushings are oil soaked like those in your photos, but the passenger side are dry.
Old Nov 21, 2016 | 08:57 AM
a2j's Avatar
a2j
At the first glance I thought there no way this was going be easy. So I removed nuts from both sides, removed mounting bolts (3) for the front diff and disconnected toe rod ends. This allowed some movement of both, steering rack and front diff. Driver side bushing were so worn out that bolt and bushings came out easy. I put the bolt the other way in for the next time I have to do it. Something is telling me that I'll have to do it again in 80-100k miles. Passenger side was good, but I replaced it anyway because I was already there. It only took extra 2 mins. Vehicle's front wheels were on ramps and I don't think I even bothered with raising it. So I thought this whole deal will take a day or two, but after 30 mins realized that I'm almost done. It took me about an hour.
I think the oil is the cause of the bushing failure. I think it's the steering rack that's leaking, but not big of a leak to notice unless you look in that area.
Old Apr 11, 2017 | 11:35 AM
2001_clk430's Avatar
CLK430
164 460 00 29 , i am having the same problem, knocking in front left driver side on bumpy road when driving slow and also can feel it on my steering wheel, will this part number fit on my 2008 gl550?
Old Jan 21, 2020 | 09:43 AM
secondbenz's Avatar
2008 ML320 CDI
Rack bushings beat me
My 2008 ML320 CDI with 150k, has a front clunk/rattle noise, and I've tried replacing the upper & lower control arms, struts, sway bar bushings and end links. Being down to one of the last likely sources, I tried swapping the steering rack bushings. But mine was no one hour job - it fought me the whole time. Removing the three differential mounts and tie rods did give me lots of play, but not enough to wiggle the driver side bushing bolt out. The passenger side came out easily and I swapped those bushings even though they were barely worn. I contemplated just cutting the passenger-side bolt off and replacing it, but decided to do the tie rod ends first. After they're done, it'll be down to the rack, as a source of the maddening front rattle I get on dirt roads and over speed bumps. Since my power steering weeps, I'll probably bite the bullet and do the rack, after the tie rods.
I love this vehicle's safety, comfort features and mileage, but I'm very frustrated with the engineering, from a maintenance and repair POV. I get the feeling that the engineers put maintainability as the *very last* concern on the list of things to optimize for. Having had to do the dreaded o-ring replacement on the oil cooler (buried in the valley of the V-8, not mounted on the front, where every other one is mounted), I've gotten to know a lot about wrenching on these vehicles and I'm certainly developing a love-hate relationship with mine. My old e300d had it's quirks (glow plugs come to mind), but these cars feel like they're made to be disposable, not repaired nor even maintained. The "lifetime" oil in the transmission is a good example of this mentality.
Old Jan 21, 2020 | 10:18 AM
eric_in_sd's Avatar
2007 GL450
I had very rapid onset clunking in the front suspension, following swaybar end link replacement. It turned out one mounting nut had simply loosened.
I ordered some M14 washers (stainless just because), hoping that a cleaner seating area for the nut will help reduce the tendency to wander loose. The hole in the swaybar end is significantly larger than the shaft.
Old Jan 21, 2020 | 10:29 AM
DennisG01's Avatar
'08 GL 320 CDI
Eric, the hole that the shaft of the end link goes through should not be noticeably larger than the shaft. It should be "just" large enough to get the shaft through - almost "snug". Either you have the wrong end link in there or because the nut wasn't tightened up enough and loosened, it allowed the hole to wallow over time from the leverage of the end link going up and down. Just an fyi.
Also, you might consider using a nyloc nut... or use some blue loctite on your existing nut... or stick a couple pieces of fishing line over the threads as you tighten the nut down (making a "locking" nut).
Old Jan 21, 2020 | 12:05 PM
eric_in_sd's Avatar
2007 GL450
Well, I noticed the play when I installed the new end links. Plus, the bar is tempered steel, so it would be difficult for a loose bolt to wear it. I'll check it out when I install the washers - also compare the bolt diameters to the new pair of links I have on the shelf.
It's possible the installed links are not at spec. They have a flat on the bolt instead of the torx end.
The nuts are Nyloc. I don't understand what's happening here.
