Changed Intake pipe to turbo
Old Nov 5, 2016 | 08:16 AM
wagga's Avatar
GL320CDI
Had traces oil droplets.
Tracked to a leaky (seal) at the air intake to turbo.
Mechanic said the new pipe has better seal then current (old) one.
Seems the old design not as good and others had the same issue.
No choice but to change.
All good now. But it is expensive for a part which could look simpler.
Old Nov 5, 2016 | 01:17 PM
alx's Avatar
alx
Or you could just change the seal with the updated seal. Much much cheaper. Next time search the forum
Old Nov 5, 2016 | 06:19 PM
wagga's Avatar
GL320CDI
That's what I thought.
Only saw the part after it was ordered.
Prior was told it needed to get a "new" seal and it came attached to the intake pipe.
I am no mechanic (bad one if I was one),
Too trusting of the workshop, but that was the closest and most convenient.
Now need to think of alternatives.
Old Nov 5, 2016 | 09:33 PM
alx's Avatar
alx
And make sure your side seal doesn't leak. It is the smaller one located on the pass side of the main seal. They are even cheaper... couple bucks
Old Nov 6, 2016 | 02:04 AM
clvincent's Avatar
e320
yes but some of the black plastic parts have cracked too
i have replaced mine on the ML and GL for cracking
so not a bad thing you did it
i change both seals each oil change
Old Nov 6, 2016 | 04:48 AM
chsu74's Avatar
GL 450, 993TT, Cayenne Diesel, 964C4
Can someone post part#s for the two seals?
Old Nov 7, 2016 | 08:12 AM
a2j's Avatar
a2j
2008 GL320CDI (310k), 2017 GLS450 (170k), 2024 Sprinter 2500 (40k)
That is the issue I'm having. Cracked plastic.
They have been posted before, and not too long ago. Just search the forum
