GL450 CODE P0730 !!http://mbworld.org/forums/images/smilies/nixweiss.gif
Old Nov 5, 2016 | 11:48 PM
adix2's Avatar
gl450
I WAS DRIVING THE CAR AND IT STOP ON SIDE OF ROAD .
NO REVERSE NO GEARS AT ALL. I RESTARTED NOTHING, NO GEARS WORKS.
I TOWED TO MY HOUSE AND HOOKED UP WITH OBD2 GAVE ME CODE P0730.
INCORRECT GEAR RATIO.
ON 722.9TRANSMISSION.
NO WARRANTY WITH 133K
Old Nov 7, 2016 | 12:20 PM
MJ50's Avatar
Super Moderator
bone stock E55 AMG
moved to X164 forum...
Old Nov 7, 2016 | 02:11 PM
carlosrg's Avatar
2023 EQE AMG
It seems to me that code is because the transmission isn't shifting.
It could be low fluid, old or dirty fluid, bad Shift solenoids, or the transmission control circuit.
Are there any other codes? Either way you need to at least replace the fluid. And go from there.
Old Nov 7, 2016 | 02:47 PM
alx's Avatar
alx
without star/das readout of the tcu a diagnosis would be a waste of time / money
it could be as simple as low tranny fluid level (did anybody do a tranny service recently? do you have any leaks?) or a conductor plate malfunction or a serious mechanical issue.
Old Nov 9, 2016 | 12:08 AM
adix2's Avatar
gl450
No dont have records of car which was bought 5 months from a shady dealer. Think change the tranny fluid might be good start.
Old Feb 15, 2018 | 05:29 AM
GL500's Avatar
GL500
Was there a resolution to this issue?
I’m stuck in Limp mode with the P0730 code..
Old Apr 6, 2018 | 10:58 AM
GL500's Avatar
GL500
Originally Posted by GL500
Was there a resolution to this issue?<br /><br />I’m stuck in Limp mode with the P0730 code..
To assist anyone having this issue in the future, mine was resolved through a transmission rebuild. Apparently the seals inside the transmission had torn.
My 2006 GL500 (The Australian GL550) had 65,000km. I had tried a transmission service - Replacing filter and ATF / draining Torque converter, this didn’t work.
I tried replacing the valve body and ordered transmission body speed sensors from China before surrendering to an independent Mercedes mechanic, who had to tear down the transmission to find the torn seals.
Ended up costing quite a bit to get it back on the road.
