brakes upgrade with amg
http://www.ebay.de/itm/Mercedes-Benz...-/221889843576
Mercedes-Benz-C215-W215-CL-W220-S-55-AMG KIT
like menber turbocad6
i one week i will have it at home
we will see, how much work...
Calipers: Which Model
Rotors: Which Model
Brake Pads: ??
Adapter: ??
Bolts: ??
Thank you.
Move the adapter with inox iron back 4 mm and inwards 3 mm
You need bigger bolts to the adapter. It is easy to find
I use the oem hoses . No problem
With oem rotors
I use our brake pad sensor
I bought brembo brake pads for these calipers... easy to find
And read all the post....
I will work in the rear brakes
The brembo pads are not good... I need to look for better ones too
To take out all of air inside the brake hoses... you will need a machine... by hand is so difficult .
