Do you have to open the lid to the brake fluid reserviour when changing brakes?
Old Dec 11, 2016 | 10:24 AM
12_gl450's Avatar
gl450
As title. Is this required? Does fluid need room to rise? Thank you.
Old Dec 11, 2016 | 10:28 AM
ItalianJoe1's Avatar
2003 CL 600
Unless you've refilled it at some point, the fluid will have space to go back up. Removing the lid doesn't change anything either way. If fluid has been added, when you push the pads back it will overflow the bottle.
Old Dec 12, 2016 | 09:20 PM
NYCGLK's Avatar
GLK 350 / Porsche 993
Just makes it easier to push pitons in.
If it's full, it will overflow when you push pistons back in.
Old Dec 14, 2016 | 01:48 PM
alx's Avatar
alx
this
Old Dec 16, 2016 | 12:38 PM
digitalhomer's Avatar
2008 GL320, 08 Jeep GC CRD, 13 VW Passat TDI
I always do, it makes it easier to push in the pistons as mentioned earlier and it makes you check the fluid level and make sure everything is ok.
Old Dec 17, 2016 | 05:27 PM
2010GL550's Avatar
GL550
+1 I do the same. Not sure if it really makes it easier, but I have always done it. I've done dozens of brake jobs over the years.
