2010 gl350 oil usage
Any advice? Egr problems? It runs fantastic and no loss of power?
Thanks,
Ron
Check for external leaks behind the engine. If oil is found there it is either your turbo intake seal ($$) or intercooler seals ($$$$). If no leaks are observed and no strong smell of burnt oil is present after shutoff I would check boost levels and engine compression.
Drives: GL350 2010
GL350 Oil Leaker
I have a 2010 GL350. At 125,000 miles it started using oil. No leaks anywhere under or around engine. I was adding a quart a week(250 miles). Took to dealer they replaced oil seals in engine $2700. After they were replaced, the car was still using a quart a week. I took it back and the dealer tested and said that one cylinder was scored and there was nothing they could do. They offered a new engine for $11,000. It has been a month and now I am adding 2 quarts a week (less than 300 miles per week). I am not sure what to do. The car runs great, no smoke, the exhaust looks clean and no oil leaks.
Any comments...would be appreciated.
