front suspension clunk
The only way to confirm your problem now would be when that strut is out if vehicle. If it is bad, you would be able to press it suddenly from top rather than slow compression.
See if you can have Arnott send you a free replacement. Then you can confirm the diagnosis during the exchange process
I'm at 55k and have had no issues with the air suspension to date (touch wood...) but I have had this clunk since 47,900. The dealer claimed that they didn't hear it (apparently they do their diagnosis with the radio blasting) and thus skirted replacing it for me under warranty.
Sak: I recently had an end link knocking sound, but absolutely could NOT replicate it while the truck was in the air, as you normally would. I took it into an Indy and they couldn't either. They checked other things out and couldn't find anything. But they were able to hear it when driving so they knew something was amiss. They threw a new end link on there (best/cheapest guess) and that solved it. Just offering that as some information for pondering. Thinking back, I wonder why I (or they) didn't just disconnect the end link and go for a drive to see if the sound went away?
We are now at 110k/mi and have had to replace the front passenger-side assembly two more times. Once for a clunking noise, and yesterday because that side was sagging with cooler temperatures and/or sitting for a couple of days. So the rear and front driver's side have all been replaced ONCE. The front passenger side three times!
Same here. Initially the dealer service couldn't replicate, but I asked them to look more and they ended up replacing front struts and it went away. But it's never quite as 'clank-free' as I'd like it when going over small street bumps in low speed in the parking lot...
arm and then drive for a week or two and inspect.
