front suspension clunk
Sounds very similar to this https://mbworld.org/forums/gl-class-...-problems.html
It got worse over the last month. Replacing sway bar links did not resolve this issue. But it sounds like worn out links. Did anybody replace sway bar bushings? How often? I still have original bushings installed. They look ok, but looks can be deceiving. This issue is very annoying. I refuse to leave it like that.
Thank you for willing to assist.
Thank you for willing to assist.still there.
hope you are luckier than me and find out your source lol...
i am very suspicious that the front stabilization bar bushings are softer than they should (even when new) and if loaded enough they will clunk.
make sure it is a clunk and not a knock. knocks are usually suspension pieces or end links. clunk is bushings. my clunk is uncurable as far as i am concerned haha...
still there.
humor me - remove one end on each side (since you have done them a few days ago it would be very easy) and check how the little balljoints move on both ends of the links- they need to be snug and move with effort. also check how tight the bolts are that connect the links to the swaybar. if aftermarket some of them use smaller diameter bolt and they will move around even if tightened until you saw stars... (the "star" method of torquing things
You could also try swapping the left one for the right one and see if the sounds follows.
I guess I will try swaybar bushings next. Or could this be failing engine mounts? But it doesn't always makes that sound. Only at lower speeds, over certain kind of bumps.
Now, I know this is not the sound you have, but it might not be a bad idea - it's easy enough, anyway - to take a close look at things in other places. It might be a wild goose chase in the end, but then again, you might get lucky!
It was very easy to duplicate, as there's a small bump going into our garage and you'd hear it all the time...until the new strut assembly.
what's next?
Also have you tried doing this :
Basically possible reasons are upper or lower ball joint or control arm bushings. Another biggie is a bad front passenger strut. Try to bounce front passenger side and then stop. If it takes more than 1.5 bounces to return to baseline, strut might be bad. Do you know when was it last replaced ?
You can try to jump on passenger side foot rail and see if you can reproduce the clunk. If yes, a partner can look or listen the source of clunk.
I am sure you have done a close inspection of all the joints in that area.
If it would have been a creak/squeak rather than a clunk, I might have suggested to spray silicon on individual bushings one by one and test driving. Clunk is usually metal to metal sound.
I am not a mechanic or car professional, just know my way around cars a bit to suggest these few things. Hope it helps.
My next attempt to fix this noise is going to be to replace the bushings on the steering rack. The one on the drivers side gets soaked by oil and it degrades the rubber. If replacing them fixes it, I'm going to make some out of polyurethane.
Since I'm the second owner, I also asked if we could review the prior service history on the car. There was a report of the same knock from the right front earlier in the car's life - another dealer replaced the right front strut and that must have cured it because the car did not knock when I bought it.
So I decided to check if my shocks are bad with a "jump around" method. Except this time I wasn't listening for the clunk, because there is none. And I have discovered a significant difference between driver and passenger side. I don't know if that is my issue with the noise, but my passenger side shock needs to be replaced. Front shocks came from Arnott, with airbags.
