2009 GL450 Malfunction message
My friend scanned my GL450,and it show two codes which is 5503 and 5508,but he doesn't know what the problem is... ( He's not a MB mechanic)
Any suggestion how to fix this problem ?
I believe, but someone correct me if I am wrong, that the 5503 is the airmatic pump taking too long to come to pressure/fill system. Not sure on the exact code on the 5508.
If I am correct about the code it's basically saying it took too long to pressurize the system. If one corner of the car is lower than the rest first thing in the morning then it is likely a leaking strut or the line that feeds that strut. If the whole car is low in the morning then there is a leak in a common part of the system.
A simplified explanation of the system is that there are 4 air-struts or air-shocks, one at each wheel just like a regular car has shocks. There are high pressure air lines connecting each of those air-struts to a distribution block that acts like a valve assembly to feed air to each of the struts as they need it. Then there is a pump/air compressor inside the front bumper that supplies the air pressure to fill the air struts.
While not a super complex system it is rather unique to MB. The code your car is giving isn't a simple "replace this part" its a more vague code that could be cause by any one of a number of parts or even a combination of several parts not working quite right.
Also check this thread
https://mbworld.org/forums/e-class-w...ml#post6065184
I wish I could buy a dinner who response my post.
I have one more question.
If it is leaking do I need to replace the pump? and what about compressor?
Thank you for your all responses again.
Best regards,
Jesse
