Reccomended seal replacement for diesel engine
Old Mar 27, 2017 | 06:22 PM
smiledr996s's Avatar
2008 gl320cdi
I am about to schedule service with a local indy for an 08 gl320 and usually try to order all the parts to make sure they are correct. I plan to do the intake and fuel filters and would like to know which seals to replace while in that area.
I think I have a oil leak from the air/oil separator. I think I have read to replace the intake and turbo seals are there any others?
Steve
Old Mar 27, 2017 | 09:52 PM
KrustyKustom's Avatar
2021 V167
That's about it unless you show any oil seepage down near the resonator or mass airflow sensor. There is a few o rings there but usually you do not replace these unless you have a pressure air leak or again a oil mist.
