Gray Grease
Old Apr 2, 2017 | 11:29 AM
B Marques's Avatar
2010 C300 4Matic, 2011 GL450, 2005 ML500, 2010 GL350 and 2003 SLK230
Gray Grease
I see some grayish grease all over front diff and axles does anyone know what that is? Have never seen anything like that before.
Old Apr 2, 2017 | 11:37 AM
ItalianJoe1's Avatar
2003 CL 600
Silicone from inside the motor mount support arms. It softens and runs out with age.
Old Apr 2, 2017 | 11:43 AM
B Marques's Avatar
Okay good. Was worried I was going To have diff issues. Anyone do motor mounts? My 4 matic c class costs an arm and leg just in labor
Old Apr 2, 2017 | 11:46 AM
2003 CL 600
It's easier on the GL than on a C-class. Labor time is about half. The part that contains the grease is not the mount but the actual metal arm that attaches from the mount to the engine block. It's filled with silicone for noise/vibration reductions, but it won't actually hurt anything when it leaks out, at some point they stopped putting the filler in there, I've seen some without it, some only filled on one side, etc. It's a bluetec only thing I believe.
Old Apr 2, 2017 | 12:16 PM
B Marques's Avatar
good to hear. I'll pressure clean and leave it alone. Thanks for your help.
Old Apr 2, 2017 | 02:31 PM
Callisto1's Avatar
2010 GL350
You don't specify which vehicle has the leak, but I'll bet it's your GL 350. They put special motor mounts in them to withstand the higher temps of the diesel, but after 5-7 years, they melt anyway and the result is a grey grease near the front diff which is on the drivers side. Presumably the pax side will go soon as well.
I assume the fluid in the motor mounts is meant to dampen vibration. Other more knowledgeable in the forum can opine on the wisdom of doing nothing. I chose to replace both mounts. Not sure the exact cost because I did the oil cooler at the same time. But $2000 +/- would be a ballpark for a dealer service just for the mounts.
And after replacement... I removed the plastic belly pan so more airflow gets to the engine compartment. Wish I'd done that 6 years ago.
Old Apr 2, 2017 | 10:46 PM
drkennyle's Avatar
2014 GL 450; 2014 C300
I try to find the right forum for GL 450.
Any tips on how to change ambient lighting for door panels and dashboards for GL450 2014... Thanks in advance for the help.
Ken.
Old Apr 7, 2025 | 03:46 PM
charlesb2003's Avatar
2005 E320, 2008 E320 Bluetec
Sorry to bump this old thread, but does anyone know the part number for that gray grease, and how much to use? Or is it really not necessary? How much vibration does it add to run without it?
