Valvoline Max Life full synthetic ATF for 722.9 tranny?
I used Valvoline MaxLife ATF from Walmart in my 2003 SL and it has worked fine for 5 years. Met the specs so I used it and no problems. I believe that is a 722.6
If it meets the specs for your 722.9, go ahead and use it no problems.
Didn't realize it meets all the newer specs (I only needed 722.6 so never looked at it after that). Will keep that in mind for my 2 other MB's with 722.9 transmissions... it's a great fluid and if it is suitable for 722.9 I will use it for sure!
What am I missing?
Lots of fluids recommend against mixing even if both are compatible.
Look at the MSDS even on Brake Fluid and you can see that different companies use different formulations. To assume a random mixture is as good as one of the engineered fluids seems like a stretch.
They may stay with one manufacturer, or move as needed, but I would bet they test the crap out of a new Mfg before they switch.
I would probably stick with MB a or Pentosin product since that seems to be their favorite. If I didn't know what was in, I would probably do a second change in less than the usual span, Maybe 20K to 40K miles.
It is not like it is going to instantly blow up the trans, but for full life 80K to 100K, I would not trust a fluid mix.
Shorten all the change times if you use the truck hard. (Towing, short drives, around town use, lots of hills, just drive hard, etc.)
What is the service history on the GL? How many miles did you get it with? Did it have more then the original owner?
I figure 90% of MBs get MB service from the original owner till the end of warranty? After that it is a guess without some insight.
I'm a business owner and like any corp mentioned above I consider cost and quality of product when I choose what to use in anything I own especially my cars and trucks since I depend on them for a living, for that matter I do that with everything, goes with being in business I guess. I say use it without worry, it meets all specs....my strong suggestion is, don't buy into the absolute masterful Mercedes add hype and all the subsidiaries that supply them, do your research on a set of products that you want to use, if they meet specs and are a reputable company go for it, put the money saved in your pocket. I'm a fanboy of Valvoline, others seem to be fanboys of Pentosin, Febi, Fuchs, pick your product based on your criteria and budget, become a fanboy and you to can argue your point on the forums with the rest of us. For some interesting reading and oil arguments head over to Bob's the oil guy website and check it out, interesting place to hang out once in awhile....good luck let us know what you decide....
Edit, LOL, I just realized how old this thread is oh well there you have it....
Dan
http://bevo.mercedes-benz.com/bevoli...ets-sort1.html
For ATF, I like Shell ATF 134 or ATF 134 FE depending on what the vehicle calls for. You can get it from a local shell distributor. Normally about $60 for a case of 12 quarts, much cheaper than the dealer which is typically around $20+ per quart.
https://www.shell.us/business-custom...r-locator.html
It's a good thing too as the change interval went from sealed for life concept to around 40,000 miles. Hope this helps and best of luck.
The instructions here (from another thread) are great, assuming you have a V8 block and the original pan. For my OM642 diesel engine, turning the flywheel to rotate the torque converter required a 27mm socket, not a 36mm.
https://bevo.mercedes-benz.com/bevol...236.14_en.html
https://bevo.mercedes-benz.com/bevol...236.12_en.html
A previous poster linked the Bevo list. If the fluid is on that list; it meets the specs. If it doesn't, then I wouldn't use it. The 722.9 uses a fluid that was designed for the tranmsmission. I can't remember the particulars, but there is a specific reason why they dyed it blue and that's so you wouldn't put the wrong fluid in there (the previous fluid was red.) I don't know if bad things will absolutely happen, but why risk it. A new tranny is $$$$ and the fluid just isn't that expensive, and is available from numerous places in the USA. I used to order from FCP Euro (who are awesome) and other places, and it was never an issue getting the right fluid.
The 71141 spec = latest generation ATF. MB and Audi use the same trans but spec different fluids....? No.
Last edited by Audi Junkie; Apr 16, 2021 at 01:18 PM. Reason: 236.20 is CVT, so it's really not that complicated.
Again, the visc and coefficient of friction of different ATFs change over their service life. So you can compare a sheared down older ATF with a newer thinner shear-stable ATF. Either way, if 6cSt fluid comes out and 6cSt fluid goes in, what are you afraid of? This fear is based on ignorance, and over-reliance on obsolete service manuals and the corresponding obsolete fluids. Basically, if you buy old Dex III and pay top dollar, you're an idiot.
How about the coefficient of friction? How is one "Universal" fluid acceptable in various transmissions? Again, the CF changes overtime and rooster tails off the chart. If you have a fluid formulated to the middle of the pack, someplace between Dexron and ATF+4, it roughly corresponds to ALL of them. Even better, the "selective" friction modifiers react appropriately to the type of friction material they are in contact with. Sounds impossible? That's because you never thought of it, and that's because you never read up on it. I did.
You might also want to read up on Maxlife ATF itself, it's the darling of tribologists for good reasons.
btw- LT71141 is the latest generation of ATF
http://www.pqiamerica.com/ATFdecembe...linemaxATF.htm
Double the additive treat rate and +40C higher flashpoint. Find me a better ATF, you can't.
https://www.mobil.com/en-hu/passenge...bil-atf-134-fe
https://www.shell-livedocs.com/data/published/en/43f8ec13-a024-48ab-9fbe-18e802dc4648.pdf
Maxlife is 6cSt, so idk how much thinner FE gets. I actually wouldn't use FE even if my AT called for it. I would use the regular version.
Bottom line, is MANY of those fluids interchange, just check their label. Mobil 1 is worth a look. Like many others, it covers a lot of specs.
Taking the example of any car from before 2000, the ATF has been improved, and even considering the Ur-fluid is folly.
