another check engine light
Old May 10, 2017 | 01:14 PM
fireman1073's Avatar
97 s320
yup another check engine light, they just keep coming.
i haven't checked what it is yet but so far its been
nox sensor $400
adblue heater $600
tires $1200
front strut $400
i can't make 12 months without a check engine light
not to mention $80 oil changes and $140 transmission fluid service
expensive junk
09 gl320 bluetec
120,000 miles
Old May 12, 2017 | 06:04 PM
N_Jay's Avatar
2019 WS222 S450 4-Matic / 2007 W211 E350 4Matic (Sold) / 2008 X164 GL320 CDI
Have you had it since new, or did you get it used?
Old May 13, 2017 | 12:51 PM
97 s320
used almost 2 years ago july 15
Old May 13, 2017 | 07:36 PM
N_Jay's Avatar
Miles?
Service records?
Previous owners?
Old May 15, 2017 | 09:39 AM
97 s320
Miles?
Service records?
Previous owners?
one owner dealer maintained, all records
many, many receipts
i guess that should have been a clue to stay away
Old May 15, 2017 | 10:03 AM
N_Jay's Avatar
Are you using a dealer to service?
Have you found a GOOD independent shop?
Transmission service is a once every 40 to 80K mile thing. If you can't afforest $140 (which is a good price) you did not budget for a MB (or anything European).
Same with $80 oil change for a diesel. ($80 once a year instead of $35 2 times for most cars.)
Old May 15, 2017 | 10:55 AM
chsu74's Avatar
GL 450, 993TT, Cayenne Diesel, 964C4
The car has cost you less than $400 per year on maintenance outside of tires for the past two years and you are complaining? This is no different than a land cruiser would cost and you are getting almost double the fuel mileage. How is this junk?
Old May 16, 2017 | 04:31 PM
97 s320
it won't make 10 months without a check engine light
01 sienna 3 years trouble free
04 tacoma 2 years trouble free
82 380sl 1 year trouble free
94 300sd 3 years trouble free
83 300d 3 years trouble free
86 vw golf 4 years trouble free
89 vw jetta 6 years trouble free
97 s320 trouble free 2 years
Old May 16, 2017 | 04:32 PM
97 s320
i do my own work
maintenance is a given, its the repairs for emissions that aggravate me
Old May 23, 2017 | 11:14 AM
97 s320
ok so code is 146100 control deviation is too large
star tool says check injector overflow something something (need special tool)
run o2 sensor test with tool (i did and its ok)
physically check turbo boost tubes for leaks (i ruled this out because of skipping at startup on occasion and surging while not in boost conditions)
light went out on its own and rough running seems to have lessened to rarely
I'm thinking bad fuel so I'm going to finish whats left in the tank 3/8 and fill with fresh fuel and some fuel clean and boost by hot shot secret
i will post results as they develop so someone else with similar symptoms can compare
thanks...Steve
You have already rated this thread Rating: Thread Rating: 1 votes, 1.00 average.
