Tips on the x164 OM642 vehicles
I know of one successful law suit against a car manufacturer for marketing a "Track Ready" car that overheats if you actually drive it on a track and there are others pending. If the OM642 can't handle being driven to the grocery store or mall then it shouldn't have been sold as such and will likely come back on MB. Will it last longer if you do some of the OP's things? Maybe. But so would any other vehicle.
There does seem to be an issue with oil sludge but no one knows exactly what that issue is and why it is happening. Sure there are several examples on MBworld but there are thousands of OM642 based engines cruising along without the issue too. All we have is anecdotal evidence. If you look around you'll find examples of other modern engines and transmissions failing pre-maturely as well.
IMO the problem is our government's massive push for MPG. It has caused the manufacturers to push every component to its limit for that extra .1 MPG so that their overall fleet MPG goes up. This will naturally lead to more failures and guess who gets to pay for it.
I have always wondered why the advice has been to leave diesels running rather than shutting them off. As a guy with an engineering degree, I can't for the life of me think of a good reason for this to be true, and that this is a hold over from the 'bad old days' of diesel engines when they were only in big rigs. I'd love somebody to explain it to me in mechanical terms. In fact, I think idling is *worse* for a modern diesel due to the DPF, which needs plenty of heat to prevent clogging, which it won't get at idle.
I do get that you want to let the turbo cool down before shutting it off.
snip
I normally chose to leave it idling until I am done!
The other reason many of the old diesels were left running in the big rigs is that, once thoroughly warmed up they simply ran better - and it took a few miles to get things back to smooth operation if they were shut off.
The amount of soot produced by an OM642 engine at idle is so small as to be negligible to the operation of the DPF.
but the main reason is that cranking the diesel is not a happy affair for the piston rings and valve train. very high static compression makes for a lot of load on the timing chain, cam lobes, etc. think of it that way- the engine crank is about 200 rpm. when it catches all of sudden you are at 600rpms... the lash on the drivetrain is significant. repeat thousands of times and the net effect might be not to our liking.
but most importantly- every time you interrupt (and later resume) the flow of oil through a motor you risk forming hot spots (where oil doesnt reach quickly) and abnormal wear at those locations.
and i like the quiet clatter when the thing is just sitting too
I rather suspect you should consider the OM642 the most sophisticated diesel you’ve seen, although it’s possible bmw has something equal or a little ahead
In any event, I’m not worrying for a nanosecond regarding letting mine idle before shutdown.
The OM642 is also used in Sprinters currently, albeit at a lower state of tune.
Oh, and just helped step daughter buy a GL 450 and it’s WAY faster than my 320 and way smoother doing it. Too bad its highway mpg is same as my city mpg. ... but there’s payback..
Trivia: redline for the Audi diesels that won LeMans multiple times was 5500 rpm. Diesels physically can’t run any faster.
