2011 GL450 SRS FRONT PASSENGER SEAT
Old Nov 11, 2017 | 12:05 PM
jortdubyabusch's Avatar
2011 GL450
I had to replaced the battery in my 2011 GL450. As soon as I swapped the battery and cranked the vehicle the SRS light came on. It wasn't on before. It says front passenger seat airbag is unavailable. I had the code reset by a independent mechanic but it keeps coming back. Any ideas? Does it just need reset manually somehow? I'm trying not to have to go to the dealership if all possible because its more than a couple hour drive. Is there anything I can physically inspect or do on my own? Thanks in advance
Old Nov 11, 2017 | 09:43 PM
DennisG01's Avatar
'08 GL 320 CDI
Does it actually say "unavailable".. or does it say "disabled"?
Old Nov 14, 2017 | 10:12 AM
2011 GL450
Neither, it says ''malfunction".
Old Nov 14, 2017 | 12:51 PM
DennisG01's Avatar
'08 GL 320 CDI
OK. It's important to have the right terminology in a post as it helps with diagnosis. Meaning, if it said "disabled", that's normal for when a passenger is not there (especially after recently being there). I'm sorry, though, I can't the answer the question based on the new info. But hopefully someone else will be able to help, given the proper terminology. The only thing I would try is to remove the negative cable from the battery for a half hour (not sure exactly how long it "needs" to be, but I would imagine 30 minutes is enough) and then reattach. Might not solve the problem, but it's easy enough to try - just in case.
Old Jun 4, 2022 | 05:50 PM
69armando's Avatar
2011 mercedes e350
X164 SRS MALFUNCTION -Front right service requested
Same issue here, replaced battery, a Mercedes Battery and SRS light came on. Ran diag, came up with codes 91C0, 91C3, 9023, 9250, 92A0. Took car to Stealership and they claimed seat needed a recalibration, they did it $169.00 and SRS light back on same night. Took it back, they said needed new sensors…$1346.30, light came back on. Took it back they claim now seat frame needs to be replaced and it cost $3200.00. What I paid I don’t get back even though it was not repaired!!!!!!!
any suggestions aside from seat frame Woolley be great let appreciated, because I have no faith in the Stealership!!!!!
