Drivers Side Mirror Turn Signal
Old Dec 27, 2017 | 05:38 PM
dhuston99's Avatar
2010 GL450
I am getting a notification in the dash for the drivers mirror turn signal light. The problem is the light actually still works. Has anyone else ran into this problem? Is this an expensive repair or something i may be able to DIY? I found a replacement part online for 50 bucks or so just dont know how to go about replacing it and not sure if i do will it fix the error since the light is still working. Any thoughts are appreciated.
Old Dec 28, 2017 | 09:14 PM
Fourdiesel's Avatar
2008 GL 320 CDI, 2004 VW V10 Touareg TDI
I found a UTube video that shows how to take the side mirror apart. Do a search there.
I have that fault all the time with mine. It turns out the mirror housing is broken where it is supposed to latch to the mounting bracket inside near the connector. I routinely fix it by merely pushing the whole housing in toward the center of the car. That engages the electrical connector enough so the fault goes away next time I start the car (the key must be turned off to reset the system). Buying a new housing is expensive AND requires custom painting so I make do for now.
Old Dec 29, 2017 | 07:25 PM
amerc's Avatar
GL450
Start by inspecting the connections from the car body to the mirror. There are multiple wires for lights and motor that are visible behind the mirror once the mirror housing is removed. Sometimes, the plug comes loose and all you need to do is push it back in. The housing comes out very easily once you disengage the locking mechanism behind the mirror glass with a flathead screwdriver.
Old Sep 4, 2020 | 02:54 PM
Edmar1914's Avatar
ML 350 2010 Blue tech
Arrow
Connection from the car body to the MIRROR got only two (2)SPRING LOADED like CONTACT that hold the MIRROR and SERVE as a LOCKING MECHANISM, its right at the back of the MIRROR.which plug are you pertaining , there are TWO ( 2 sets ) of plug I found at the back of the MIRROR LOCKING MECHANISM, One have four wire on it, which I believe, a conductor wire ( one RED AND one BLACK) leading to LED LIGHT, and the other two which is two back that leading to the BULB at the BOTTOM part of the MIRROR ASSEMBLY HOUSING ,facing the GROUND and it will lite once you open it, the other SET of PLUG is the ONE going directly and SOLDERED to the BACK of the mirror which I believe it is for MIRROR HEATER (please correct me If Im wrong,I never see yet the electrical DIAGRAM of the vehicle, please advice of what you discover, looking forward for your next discovery.
Old Nov 5, 2020 | 09:47 PM
Xfireracer's Avatar
2017 C63S Coupe, 2001 SL500
Yes, it ended up needed all new wiring in the mirror.
Old Nov 5, 2020 | 10:09 PM
Edmar1914's Avatar
Left turn signal led light in the mirror
Hello Guys,
Good evening! I did dismantle the side mirror and at the back of the mirror there is a conduit leading to the (LED) one black and the other one is red with strife black, the other set is two pcs. also which has black in color leading to incandescent bulb facing downward to the floor. I continue tracing the wire which supply the (LED) and I found out that two (2) pieces was broken and the two remaining is almost cut,.the wire is really brittle, ( my car is almost 10 years old, it is ML350, 2010), I did solder it to joint together and use a shrink tube and everything works fine, thank you to all of you that help me to have the idea. have a pleasant day!
