Please help with Radiator Fan running all time / no heat
Old Jan 1, 2018 | 05:01 PM
machie38's Avatar
2010 GL450
Please help
My drive belt & pulley broke.
I did drive the car some and it did go into the red to shut off.
Today I changed pulley & belt but, after start up the radiator fan kicked into high gear & not shutting off until 2-3 minutes after key removal.
Plus no heat.
Please help as I have my mother In-law's funeral on Thursday and need to fix this.
Mike
machie38@OUTLOOK.COM
347-728-7290
Old Jan 2, 2018 | 08:15 AM
alx's Avatar
alx
Fan system needs to be tested in star/ das. It could be many things. The fact that you cooked the engine a bit doesn’t help either and might complicate things a bit.
Old Jan 2, 2018 | 10:00 AM
luxcar's Avatar
08 GL550, 08 BMW 550i, 07 MDX
Originally Posted by machie38
Please help
Plus no heat.
Mike
347-728-7290
Check the coolant. There were some air bubbles in the coolant and heat was not turning on. I opened the radiator reservoir cap and let the air out and topped it off. After couple of iterations the heat started working.
