Leaking Arnott bags/Experience ?
Old Jan 22, 2018 | 12:03 PM
rayray999's Avatar
Saab Crazy
I was on the fencee for the Arnott shocks, and opted for the Bilstein for the front shocks/bags replacement, and I have had no issues with them.
But for the rear, I decided to with Arnott, and now after 2 weeks one of them is leaking, and the car sits on the ground on that side every morning.
Since it needs to be replaced, should I forgo the hassle, and just replace it with bilstein, or give them another chance ?
Any thoughts ?
Old Jan 22, 2018 | 03:26 PM
mefferso's Avatar
BMW 335d
Any thoughts ?
Are you sure the bag itself is leaking? Check the nut that connects the air line to the bag. Both of mine were only hand tight new out of the box. I sprayed soapy water to confirm air was leaking around that nut. I used a small wrench to tighten and that fixed the problem.
Old Jan 22, 2018 | 06:23 PM
rayray999's Avatar
Saab Crazy
I did by hand, but was afraid to use a wrench, as they had sticker on there that had wrench crossed out ..
I'll check it again today, but called Autohausaz, and they told me to send it back for a refund ... But since I had thrown my old one out, I ended up buying a new one, and once that arrives, I will send this one back, and hopefully get the refund ...
This car has been nothing short of a service disaster with things going wrong with it .. I just want to get it to a point where I can sell it, and move on to another brand .. We can't seem to go more than 2000 miles without something needing to be fixed on it ... I should have never bought it, as this car truly is a disposable car after 45k miles ...
Old Jan 22, 2018 | 06:56 PM
BlownV8's Avatar
E55, GLS450, GL63, GLE350
You must have a diesel GL?
Old Jan 22, 2018 | 07:08 PM
rayray999's Avatar
Saab Crazy
Indeed, it is a diesel, and we bought it to replace our Ford Expedition for better fuel economy ...
It does give better fuel economy, but the out of pocket cost since the extended warranty ran out would have allowed us to drive the expedition another 60,000 miles, and that car went 80k miles with just oil changes, and one transmission flush while towing my 8500 pound boat - never had any issues ..
We have never towed with this car, and with my experience, it truly has been a garbage of a car to own, and soured my interest in any future Mercedes..
So, are you telling me the gas versions are more reliable, and it deserves a second chance ?
Old Jan 22, 2018 | 08:14 PM
kombifan's Avatar
2010 Mercedes GL450; 2000 Mercedes ML55 AMG; 2016 VW GLI SEL Stick!!!
Fellow gasser owner here.
Yes the 450s are definitely more reliable, but I think a lot of the diesel woes come from an inadequate amount of oil....etc
Only big issues have been the idler pulley and suspension replaced around 6-7 years with 60-75k on the clock.
All covered under extended warranty.
Minor gripes. Keyless go sensors and rear led taillight had to be replaced as well as srs connector.
Definitely deserves a second chance! 😁
Old Jan 22, 2018 | 09:52 PM
YodaSyrup's Avatar
X164 GL550, F10 535 6MT
Kombifan, which srs connector did you replace? Side curtain?
Old Jan 22, 2018 | 09:53 PM
BlownV8's Avatar
Love my 450. It's an amazing vehicle and has been ultra reliable. Still going strong with close to 250k miles. There are common issues across all engines but the diesel seems to have it's own special problems. The gasser gets poor mileage but I've been running regular unleaded for as long as I can remember. Regular unleaded is around 20% lower than diesel in my area so the mileage difference doesn't matter much.
Old Jan 22, 2018 | 10:09 PM
kombifan's Avatar
Hey Yoda.
The connector was for the front passenger seat belt. The srs connector is designed in such a way that it is tucked away under the front passenger seat and easily accessible to the feet of second row passengers.....
Plastic connectors and feet do not mix well...
Blownv8
I regularly get 16 mpg...whilst the average over the last 9000 miles is around 14.2 mpg in mostly city driving.
Whilst not great it's not atrocious. Perhaps your gas mileage might be due to running regular? The engine does adjust timing and often that means to worse performance in horsepower and gas mileage due to having to compensate for lower octane resulting in higher emissions, higher exhaust gasses and worse fuel economy.
Old Jan 23, 2018 | 08:24 AM
BlownV8's Avatar
I average over 16 mpg and get around 20 on the highway. Interstate speeds of 70 mph or greater averages around 17. I'm also running 22" wheels and tires. Those cost me over 1 mpg. I was averaging 17.7 mpg on the stock 19" wheels and tires.
There may be a very slight difference in power but my mileage did not suffer with the switch. My car actually idles much smoother with regular than super and I suffer from no drawbacks. I made the switch around 100k miles.
Old Jan 23, 2018 | 05:26 PM
rayray999's Avatar
Saab Crazy
kombifan,
I have always used all Mercedes branded parts from the dealership that I bought myself, and only used approved Mercedes Mobil-1 diesel oil adhering to the manufacturer specs... And even at $12 a quart, I have checked the oil on that car on a weekly basis ... So, I will disagree about the oil having anything to do with it ..
But speaking of oil ......yes that car has had it's oil cooler seal replaced twice, and the first time they even rerouted the hose rubbing the radiator fan, where is tore into the hose, leaking coolant, and leaving us stranded 150 miles away from home ... And then they even made me pay for the entire service, and told me to chase down the other Mercedes dealer .... Joy ....And even after after all of that the POS car still leaves oil drops everywhere ...
Question for you gassers, having paid over $3000 for changing the hydraulic engine mounts that creamed gray paste all over my garage, and to this day I see a splat here and there forcing me to wonder if it was the old leak or new leak. Do the gassers also use the crap hydraulic engine mounts?
Old Jan 23, 2018 | 07:27 PM
kombifan's Avatar
kombifan,
Hey ray ray
I don't doubt your attention to detail regarding the maintenance schedule, but it was merely more hinting at an oem issue of inadequate oil flow through the bluetec engine in the gl350....
We've always lusted for the diesel gl's....and I've read plenty in the forums and it seems a lot of the engines suffered from sludge and improper oil flow/oil temperatures
That sucks! You have my sympathy.
Either one of those mb dealerships should have stood up to eat the cost.
Considering I don't know and havent experienced anything about the engine mounts....I don't think they do.
I think it might have been engine specific to the diesel to insulate the cabin from the diesel vibrations.
I had high hopes for diesels...I wish they would bring them back.
Old Jan 24, 2018 | 07:48 AM
BlownV8's Avatar
Mine are still original.
Old Jan 29, 2018 | 11:53 AM
rayray999's Avatar
Saab Crazy
I thought that I would provide an update.
I received the new suspension airbag, and this time checked the nut, and it was very tight, so no need to tighten ... I removed the faulty bag (had to cut the tip off, as I did not find a way to get the air hose out without undoing the valve) ....
The faulty bag also had the valve nut very tight, so I don't think it was a lose nut issue.
I also did not see any defects or damage visually on the bag itself ...
After a few days the air is holding, so I will just attribute that to the list of all the unlucky problems that I have had ...
Old Jan 29, 2018 | 06:07 PM
GLguy's Avatar
09 GL450
Well, I'll be replacing front passenger one this weekend. After 8 year and 55K. Did the driver side 4 months ago.....Saw it dropped two days ago.....
Old Jan 29, 2018 | 11:39 PM
EWT's Avatar
EWT
11 ML550, 95 Supra TT, 14 Audi S4
I had one of their front shocks fail after a little more than 2 years and I think the other is now failing after 1.5 yrs. The left front corner was low once a couple of weeks ago and it hasn't repeated, but failing front shocks seem to start off that way. I'll jack it up and check for leaks with soapy water if it drops again although when I did that with the right front, it went from dropping every 2-3 mornings to audibly leaking and dropping almost immediately after the engine was shut off. Jacking the car up and extending the shock all the way to check for a leak seemed to enlarge whatever hole was there significantly.
I hoped they'd last longer than the MB part, but at least they have been great so far honoring the lifetime warranty. Once it is replaced, I will be on set #4 of front shocks @ 178K mles. I put the Arnott rear air bags on about 2.5 years ago, and they're still going strong, but the original rear air bags lasted much longer than the fronts (only on set #2)
Old Jan 30, 2018 | 02:47 PM
qcman's Avatar
2012 GL550
Curious to know if anyone has ever used a liquid penetrant inspection on rubber material.
Old Jan 30, 2018 | 03:05 PM
DennisG01's Avatar
'08 GL 320 CDI
Wouldn't that just show cracks all over the place? Meaning, the entire rubber surface (even new ones) have imperfections all over the place - which is normal for this type of material.
Soapy water.
Old Feb 1, 2018 | 08:28 PM
qcman's Avatar
2012 GL550
Soapy water.
Im not certain, the rubber skin could be porous and make it look like the spring is bleeding. Was just a thought. With the soapy water, you need access to all lines as well as full view of the spring. If its a small pinhole leak on a hard to see area, it could be missed. Maybe im just over analyzing here.
Old Feb 2, 2018 | 10:18 AM
DennisG01's Avatar
'08 GL 320 CDI
Maybe I don't fully understand how that stuff works, but don't you still have to visually see it? If that's true, how is that any better than the soapy water? But, a mirror on a stick (or cell phone on video) can get into many places that you can't with your head. Sometimes, with the soapy water, you can hear the leak, too.
The bags are not porous. If they were, they wouldn't hold air.
Old Feb 4, 2018 | 10:43 AM
qcman's Avatar
2012 GL550
When I meant porous I was talking about the surface only. But you're right about the soap test. It would be easier. Was just a suggestion / thought.
Old Feb 4, 2018 | 02:38 PM
DennisG01's Avatar
'08 GL 320 CDI
OK, gotcha. Yes, that was what I was referring to in post #18.
