Starter Location
https://mbworld.org/forums/gl-class-...e-starter.html
I imagine the referenced post may convince you to have the starter replaced by a professional. Can save some $$ with an independent shop, just try to verify they have Mercedes experience. Also let that shop determine the part they want to install.
There is a good chance your Mercedes dealer can source a Mercedes rebuilt starter.
Whoever replaces the starter will also need to perform all the "reset" procedures required when battery is disconnected ... this was not mentioned in the referenced post.
I have used "OEM" starters and alternators in the past when in a pinch, like out of town in a rural area with no MB dealer around but there was an autozone or an advance auto. and it has bit me a time or too.
As for OP doing this repair. if you normally go to a shop for repairs, I wouldn't make this one the first you try to tackle... I would maybe start with changing your oil, spark plugs. or serpentine belt.
. I didn't know Infiniti made a Lambo. Lamborghini is owned by the VW Group, more specifically Audi.
