GL550 Power steering fluid leak (2008)
Old 09-07-2018, 12:29 PM
gricer48's Avatar
GL550
Question GL550 Power steering fluid leak (2008)
I have a leak at the power steering input shaft seal and at seal between reservoir and pump. Mechanic recommends replacing pump/reservoir assembly and installing steering head repair kit. Expensive job. Has anyone had this problem? What was cost to repair. Thanks!
Old 09-10-2018, 01:47 PM
jonathankreb's Avatar
'98 E320 and '08 GL320
I think I am seeing the exact same leak on my 2008. Did you get an initial estimate from your mechanic?
Old 09-10-2018, 01:52 PM
gricer48's Avatar
GL550
My mechanic (not MB dealership) estimated $1,300 and would need the vehicle overnight. He is a MB trained mechanic with lots of credentials.
Old 04-09-2020, 02:41 PM
SKGL450's Avatar
Mercedes GL 450 4.7
Leak between pump and reservoar solved
Hi
I had a problem between pump and reservoir.I replaced the seal that goes on the conus shape on the pump and everything is ok now .No leaks.
it takes me about 3 hours to get this job done .The seal is about 5 buks .
Good luck
Quick Reply: GL550 Power steering fluid leak (2008)
